2005 Single cab short-bed with V-10 6.8L engine.
Old Oct 15, 2006 | 10:34 AM
  #31
rafa26's Avatar
Got some bad news guys,
Doing my research about the Ford V-10 6.8L i recently found out that the V-10 cranks are not strond enough to support a turbo and very high HP.
That was posted by Neal "The hp freak" on the lightning forum:
"HI!... The crank is very weak in the v-10 and is known for breaking at higher HP #'s. I was going to build up a v-10 a few years ago to put in mu F-150 but after seeing the crank and talking to a few buddies that work at FORD's here in WINDSOR that are in the foundry and the assembly line I scrapped the idea."
"HI!... The V-10 crank is forged. It's off-set cut due to the firing order. If you ever saw one you would wonder why it does break at idle let alone 6000RPM on a 500RWH.P application."
"HI!... No, actually it's the way the crank is built. The 4.6/5.4 cranks use 100% of the cranks center core. The v-10 only uses 50% of the cranks center core in some spots, due to allowance for the odd firing order."
https://www.f150online.com/forums/sh...d.php?t=200678
Will have to try to find a another bigger engine because the V-10 is out of the game now.
Old Oct 15, 2006 | 10:56 AM
  #32
GerRod's Avatar
Below is a video where a 5.4 L (Ford GT) was twin turbo'ed to 1,000 hp...don't know if you can make it with a truck with the drive train losses...probably can run the same times with 900 hp...after about 800 hp, chassic setup will become your biggest obstacle...
http://www.torquenstein.net/movies/i...s_JoesGTTT.wmv
Old Oct 15, 2006 | 11:06 AM
  #33
mcdover's Avatar
Rafa,
There's a local guy here where I live pushing over 900 rwhp in a 4.6L Mustang twin turbo. It's easily a 9 sec. car. My question is why not build a more common smaller displacement motor and reap the cost/weight advantage?
Old Oct 15, 2006 | 11:25 AM
  #34
azmidget91's Avatar
rafa with the money your putting into your rides get a custom crank built and custom cam with a different firing order
Old Oct 15, 2006 | 11:32 AM
  #35
MBullard's Avatar
Yeah, I mean it's still a V-10.
Just beef it up. I assume you would have to do this with any motor, if you're wanting it to support higher hp. Projects like this, are the reason companies such as Edlebrock are able to stay in business. Don't give up on the V-10!
Old Oct 15, 2006 | 12:06 PM
  #36
rafa26's Avatar
Do you guys think that SCAT could do a Forged crank ?
http://www.scatcrankshafts.com/
http://www.scatenterprises.com/
Which company is better ?
Old Oct 15, 2006 | 03:27 PM
  #37
azmidget91's Avatar
i believe those are the same company i know scat made V4's for midgets back in the day and they were the engine to have it was basically a big block chevy v8 cut in half, im sure with your open check book budget they can build you something
Old Oct 16, 2006 | 07:12 AM
  #38
gatortech's Avatar
why not use the 5.4 4 valve? mated with a new 6r tranny?
Old Oct 16, 2006 | 10:25 AM
  #39
rafa26's Avatar
What's the 6R tranny?
Old Oct 16, 2006 | 11:36 AM
  #40
a n t h o n y's Avatar
Banned
6-speed, 2009 the F150 will get that tranny.
When you say fast single cab one truck comes to mind... The 2004 Bonspeed F150, 5.4 4v, t-56, navi IRS
Old Oct 16, 2006 | 11:44 AM
  #41
rafa26's Avatar
The dude here said that tranny will be available for f-150's on 2009 only.
  #42
gatortech's Avatar
also found in the 07 expiditon
Old Oct 16, 2006 | 01:18 PM
  #43
khendrix2374's Avatar
Originally Posted by BestNTx
The fastest truck in the world is a truck with a diesel engine...
That's top speed.. think he's talking about 1/4 mile.
This truck might have you beat already Rafa: https://www.f150online.com/galleries...1089&anum=7591
https://www.f150online.com/forums/sh...d.php?t=183471
here's a thread about it. I have read some places on the net that it has a v6 with twin hair dryers.....
I cant find solid specs about the engine.. but obvisually.. it has a twin turbo setup.
Here is another site: http://www.robidaconcepts.com/page/page/1916737.htm
Old Oct 16, 2006 | 03:45 PM
  #44
05supercrew's Avatar
I live 15 minutes from PSP and I would love to see that.
Old Oct 16, 2006 | 04:02 PM
  #45
rafa26's Avatar
On the link above they say the truck has 1000 streetable HP, don't know if it's on the tires or flywheel.
