Vehicle specs
Old Oct 9, 2006 | 05:17 PM
JNC995's Avatar
Vehicle specs
Is there a website that you can find out the exact specs on your truck by running the VIN? Just curious as to what gears are in my truck.
Old Oct 9, 2006 | 05:21 PM
FX4Firefighter's Avatar
i wonder that too
Old Oct 9, 2006 | 05:28 PM
Just look at the tag on the driver's door. The code is there, then do a search for the thread where someone has posted the codes and what they represent.
Old Oct 9, 2006 | 05:50 PM
a n t h o n y's Avatar
Banned
Vehicle Identification Number
  • The first 3 vehicle identification number (VIN) positions are the world manufacturer identifier.
    1FT — Ford Motor Company, USA, truck (completed vehicle)
    5LT — Ford Motor Company (Lincoln), USA, truck (completed vehicle)
    Brake Type and Gross Vehicle Weight Rating (GVWR)
  • The fourth VIN position is the vehicle brake type and gross vehicle weight rating (GVWR) code, all vehicles use hydraulic brakes. This code may also identify the vehicle safety restraint system.
    R — 6,001-7,000 pounds GVWR with driver and front passenger air bags — F-150
    P — 7,001-8,000 pounds GVWR with driver and front passenger air bags — F-150/Mark LT
    V — 8,001-8,500 pounds GVWR with driver and front passenger air bags — F-150
    Line, Series and Body Type
  • VIN positions 5 through 7 indicate the vehicle line, series and body type.
    F02 — F-150, rear wheel drive (RWD), regular cab, 6.5 ft. flareside
    F04 — F-150, four wheel drive (4WD), regular cab, 6.5 ft. flareside
    F12 — F-150, RWD, regular cab, 6.5 ft. or 8 ft. styleside
    F14 — F-150, 4WD, regular cab, 6.5 ft. or 8 ft. styleside
    W12 — F-150, RWD, Crew Cab, 5.5 ft. or 6.5 ft. styleside
    W16 — Mark LT, RWD, Crew Cab, 5.5 ft. styleside
    W18 — Mark LT, 4WD, Crew Cab, 5.5 ft. styleside
    W14 — F-150, 4WD, Crew Cab, 5.5 ft. or 6.5 ft. styleside
    X02 — F-150, RWD, SuperCab, 6.5 ft. flareside
    X04 — F-150, 4WD, SuperCab, 6.5 ft. flareside
    X12 — F-150, RWD, SuperCab, 8 ft. styleside, 5.5 ft. styleside or 6.5 ft. styleside
    X14 — F-150, 4WD, SuperCab, 8 ft. styleside, 5.5 ft. styleside or 6.5 ft. styleside
    Engine Type
  • The eighth VIN position is the engine type (displacement and number of cylinders).
    2 — 4.2L, OHV, V6, EFI — F-150
    5 — 5.4L, 3-valve, SOHC, V8, EFI — F-150/Mark LT
    V — 5.4L, 3-valve, SOHC, V8, EFI, Flex-fuel — F150
    W — 4.6L, SOHC, V8, EFI — F-150
    Check Digit
  • The ninth VIN position is a government-assigned, computer-generated check digit.
  • The tenth VIN position is the model year code.
    6 — 2006
    Assembly Plant
  • The eleventh VIN position is the assembly plant code.
    F — Dearborn — Dearborn, Michigan, USA — F-150/Mark LT
    K — Kansas City — Claycomo, Missouri, USA — F-150
    N — Norfolk — Norfolk, Virginia, USA — F-150
    Build Sequence
  • VIN positions 12 through 17 are an alphanumeric code for the vehicle build sequence. This is also the vehicle serial and warranty number.
    A00001-F99999 — F-150
    J00001-L99999 — Mark LT
    Vehicle Certification (VC) Codes
Old Oct 9, 2006 | 05:53 PM
Banned
Vehicle Certification (VC) Label Locator
The vehicle (VC) label contains information on the manufacturer name, the month and year of manufacture, the certification statement and the VIN. This label also includes gross vehicle weight (GVWR) information.
  • Exterior Paint
    Exterior paint codes may be listed as a 2-part code. The first set of characters identify the primary body color. The second set of characters (if applicable) identify the vehicle accent or 2-tone body color. All colors are base coat/clear coat.
    Primary Exterior Color Codes
    AQ — Arizona Beige — F-150/Mark LT
    CX — Dark Shadow Gray — F-150/Mark LT
    E4 — Vermilion — F-150
    F6 — Ceramic White — F-150
    HG — Smokestone — F-150/Mark LT
    JL — Dark Toreador Red — F-150/Mark LT
    L2 — True Blue Pearl — F-150
    LD — Medium Wedgewood Blue — F-150
    P5 — Aspen Green Metallic — F-150
    T5 — Dark Copper — F-150
    T7 — Charcoal Beige — F-150
    UA — Ebony — F-150/Mark LT
    YN — Silver Metallic — F-150/Mark LT
    YZ — Oxford White — F-150/Mark LT
    Exterior Accent Color Codes
    Wheelbase
    126 — 126 inches (3,200 mm) — F-150
    133 — 133 inches (3,378 mm) — F-150
    139 — 139 inches (3,531 mm) — F-150/Mark LT
    145 — 145 inches (3,675 mm) — F-150
    150 — 150 inches (3,810 mm) — F-150
    163 — 163 inches (4,140 mm) — F-150
  • Interior Trim
    Interior trim codes are listed as a 2-part code. The first character identifies the interior trim type. The second character identifies the interior trim color.
    Interior Trim Type
    A — Cenery vinyl, 40/20/40 — F-150
    B — Impulse cloth, 40/20/40 — F-150
    C — Mortar cloth, 40/20/40 — F-150
    D — Harley Davidson leather, 40/console/40 — F-150
    E — Imola leather, 40/20/40 — F-150
    F — Brick cloth, captain chairs — F-150
    G — Impulse (2-tone), 40/20/40 — F-150
    H — Imola leather, captain chairs — F-150
    J — Link Weave leather captain chairs — F-150
    K — Antiline leather, 40/console/40 — F-150 (King Ranch)
    L — Impulse (2-tone), bucket seats — F-150
    M — Brick cloth, 40/20/40 — F-150
    N — Brick cloth (2-tone), 40/20/40 — F-150
    P — Brick cloth (2-tone), captain chairs — F-150
    Q — Link Weave leather (2-tone), bucket seats — F-150
    R — Impulse cloth, captain chairs — F-150
    S — Mortar cloth, 40/20/40 — F-150
    T — Cenery vinyl, captain chairs — F-150
    U — Mortar cloth, 40/console/40 — F-150
    V — Nudo leather, 40/console/40 — Mark LT
    Interior Trim Color
    B — Ebony — F-150/Mark LT
    E — Medium Flint — F-150
    W — Medium Pebble Tan — F-150/Mark LT
    Tape/Paint Stripe
    Tape and paint stripe codes do not apply.
  • Radio Type
    5 — Premium electronic AM/FM stereo with compact disc (CD) player — F-150
    6 — Premium electronic AM/FM stereo with CD changer, clock and MP3 — F-150
    7 — Electronic AM/FM stereo clock — F-150
    B — AM/FM stereo with CD changer, clock and MP3 — F-150/Mark LT
    K — Premium electronic AM/FM stereo with CD player, cassette and clock — F-150
  • Axle Type
    19 — 3.55 non-limited slip — F-150
    25 — 4.10 non-limited slip — F-150
    26 — 3.73 non-limited slip — F-150/Mark LT
    27 — 3.31 non-limited slip — F-150
    B5 — 4.10 limited slip — F-150
    B6 — 3.73 limited slip — F-150/Mark LT
    H9 — 3.55 limited slip — F-150
  • Transmission Type
    A — 4-speed automatic, 4R70E — F-150
    F — 4-speed automatic, 4R75E — Mark LT
    M — 5-speed manual, M5R2-C — F-150
    Q — 4-speed automatic, 4R75E (Livonia) — F-150/Mark LT
  • Spring Code
    Spring codes are listed as a 2-part code. The first characters listed identifies the front springs. The second character listed identifies the rear springs.
    Front Springs
    A — 4L34-5310-AAA — F-150
    B — 4L34-5310-BAA — F-150
    C — 4L34-5310-CAA — F-150
    M — 4L34-5310-MA — F-150
    N — 4L34-5310-NA — F-150
    P — 4L34-5310-PA — F-150
    R — 4L34-5310-RA — F-150/Mark LT
    S — 4L34-5310-SA — F-150/Mark LT
    T — 4L34-5310-TA — F-150/Mark LT
    U — 4L34-5310-UA — F-150/Mark LT
    V — 4L34-5310-VA — F-150
    X — 4L34-5310-XA — F-150
    Y — 4L34-5310-YB — F-150
    Z — 4L34-5310-ZB — F-150
    Rear Springs
    M — 6L34-5560-MB — F-150/Mark LT
    P — 4L34-5560-PM — F-150
    R — 6L34-5560-RB — F-150/Mark LT
    S — 4L34-5560-SD — F-150
Old Oct 9, 2006 | 06:31 PM
JNC995's Avatar
Thx for the info.
Old Oct 9, 2006 | 06:45 PM
kingfish51's Avatar
a n t h o n y 's info really needs to be a sticky somewhere. It's too good to lose.
Old Oct 9, 2006 | 08:41 PM
SuperSport1985's Avatar
Sweet thats something I've been looking for thats cool that my truck has a 3.75 limited slip screw
Old Dec 18, 2006 | 11:38 PM
GordoPanocho's Avatar
Registered User
Don't mind this post. I've just had to come find this thread a few times and it'll be easier if I can specify my own name as a poster within it.
VIN door sticker code Vehicle Identification Number
