Floor Jack & Oil Change Questions
I'm about mechanically inclined as Bill Gates, but the motivation is there so I have to ask lame questions sometimes like the following.
First, what size floor jack would I need for my truck? Will 1 1/2 ton work or a 2 ton? I saw recommendations for a Roush 3-ton aluminum from Sam's or Costco which I'll probably get, but I was wondering what weight rating was necessary. I did search, I swear.
Second, does anyone have an oil change how to for dummies? I know what oil and filter I'm going to use (Mobil1 5w-20 and Motorcraft FL-820S) and I'm going to get the Craftsman universal oil filter wrench. Could you guys fill me in or point me to a step by step of the oil change process?
Thank you for the help.
Floor jack, 2 ton would suffice as long as it has a long reach for lifting trucks and SUVs. I don't think you'll need one to change the oil unless you have short arms or a big gut.
Oil change advice: keep the oil pan plug removed until after the filter has been changed. I get 1/4 to 1/2 quart of oil more out of the engine once the filter is removed. It requires an extra oil catch pan, but otherwise mine doesn't take the whole 7 qts afterwards.
Grim
Originally Posted by Grim
Just to reiterate what is written above, a two-ton is enough, but I recommend going with a three ton. I have two two-ton floor jacks from different manufacturers and neither of them is tall enough to lift the truck without a block (which is dangerous).
Grim
Grim
Good to know, thanks.
![thumbsup](https://www.f150online.com/forums/images/smilies/thumbsup.gif)
By the way, the fumoto F-106 is the right valve for my 5.4l '06, correct?
I would get the nipple, then you can drain the oil straight into a container,
and would only need an oil pan under the filter.
