Help!! Truck Died!!
DANGit......sounds like you're close then, maybe a Ford tech can jump in here and help with that last issue you seem to have......pretty impressive you've been able to get it tracked down to this point......! Sorry, the only help I can give you here is moving this back to the top.
Here's the deal.. I finally got it fixed.. I had to change almost all of the wiring in and around the engine cause i really got tired of searching... The car runs normally and its ok (for now)
Problem is i got these new Codes...
P0053
P0054
P2195
P2196
I went to the OBD- code site but couldn't locate these codes...
Can anyone help with these?
Thanks Guys...
P0053
P0054
P2195
P2196
Thanks Guys...
[QUOTE=MiMiK]Here's the deal.. I finally got it fixed.. I had to change almost all of the wiring in and around the engine cause i really got tired of searching... The car runs normally and its ok (for now)
P0053
P0054
P2195
P2196
HERE YA GO DUDE .. I GOT IT FOR YA ... WHAT ELSE?
code PO053 --- HO2S HEATED RESISTANCE (BANK 1 SENOR 1 )(LOCATED ON DRIVERSIDE FRONT)
code PO054 --- HO2S HEATED RESISTANCE (BANK 1 SENOR 2) (LOCATED ON DRIVERSIDE BACK )
code P2195 --- O2 SENSOR SIGNAL STUCK LEAN (BANK 2 SENSOR 1) LOCATED ON (PASSENGER SIDE FRONT )
code P2196 --- O2 SENSOR SIGNAL STUCK RICH (BANK 2 SENSOR 1)
P0053
P0054
P2195
P2196
Originally Posted by brandonhadnot
I Have A Couple Books Of Codes.. And Ripped Off A Ford Service Manual.. From The Dealer.. Hope It Helps You Out.. I Got All Kinds Of Codes Let Me Know If You Need Any Others
