tire rubbing problem
Old Sep 25, 2006 | 03:17 PM
jball1220's Avatar
my front tires are rubbing in the back of the wheel well, and pulling off the fender. any ideas how to fix this? what part do i need to trim?
Old Sep 25, 2006 | 03:22 PM
before anyone can help, they will want to know year of truck, 4x4 or 4x2, size of tires and wheels, whether it is lifted or lowered or stock.
Old Sep 25, 2006 | 03:34 PM
a n t h o n y's Avatar
Banned
The FTS 14" lift kit should do the job!
Old Sep 25, 2006 | 06:57 PM
jball1220's Avatar
sorry, its a 06 screw 4x4, 2.5 leveling kit and 3in body. with 35s.
Old Sep 25, 2006 | 07:02 PM
Dog'em's Avatar
What wheel are you using ? If it is an aftermarket rim, how wide and what is the backspace measurement ?
Old Sep 25, 2006 | 07:07 PM
TonkaTruck33's Avatar
what kind or wheels do u have?? (edited:question asked) stock wheels WILL be a problem to solve the problem buy aftermarket wheels.
Old Sep 25, 2006 | 07:54 PM
jball1220's Avatar
tires 325/65/18 nitto terra grappler. wheels are 18x9 helo maxx 6. not sure on the backspacing.
Old Sep 25, 2006 | 08:19 PM
ThumperMX113's Avatar
Have you cut anything yet? If not you need to trim the back side of the inner fender liners. Do you have the factory fender flares? If you do, you need to make a 45 degree cut on them and you'll be good to go.
Old Sep 25, 2006 | 08:20 PM
Dog'em's Avatar
I disagree. The problem stems from an aftermarket 9" wide rim compared to the stock 7.5" rim. The problem is further complicated by an aftermarket rim with backspacing anywhere from 4" to 5" depending on which one he bought, compared to the 5.5" backspacing of the stock rim.
From all of my research and advise from this site, you need to stay as close to stock as you can in order not to have rubbing issues.
Old Sep 25, 2006 | 08:22 PM
Dog'em is right. Its much easier to clear larger tires with stock wheels rather than aftermarket wheels, other than the chance of rubbing on the spindle.
Old Sep 25, 2006 | 09:02 PM
jball1220's Avatar
well i already spent the money on the rims and tires, so i guess i'll be cutting. what should i use to cut it with? does anyone have pics of where and what to cut?
Old Sep 25, 2006 | 09:04 PM
Use a dremel.
I just told you where you need to cut. I'll load the picture of my old truck in my gallery and post it. Hold on. Okay here you go, of course this was before I smoothed everything and made the lines clean. I just wanted to make sure it didn't rub before I cleaned it up and wasted that time and effort.
Old Sep 25, 2006 | 09:45 PM
jball1220's Avatar
thanks alot thumper. i appreciate it.
Old Sep 25, 2006 | 10:49 PM
Dog'em's Avatar
Thumper, did you just trim the lip of the fender flare or did you go deeper and also take some of the fender well liner ?
