Tow package question
Old Sep 15, 2006 | 08:39 PM
shtrdave's Avatar
I got the tow package on my 05, I see there is a big plug on the back, I haven't looked to see how many pins are in it, as I never had a need to find out. But a guy just emailed me and asked if I could drag a trailer for him. It has brakes and a 7 pin connector.
So how many pins are in there, if any, and is there a brake controler somewhere in the truck, or do I need to add that myself?
thanks
dave
Old Sep 15, 2006 | 09:09 PM
cndcowboy's Avatar
I am 90% sure it is a 7 pin connector
You need to add your own brake controler. There is a wire harness that should be in your glovebox that will allow for easier installation of the brake controller.
Old Sep 15, 2006 | 09:13 PM
poptop's Avatar
tow
you have a 7 wire setup like was said you need to have an electric brake controller added you need to check also the fuse box you may need to install a fuse for the electric brakes ussually a 30 amp maxi fuse . ford leaves them out to save money
Old Sep 15, 2006 | 09:22 PM
-TXF150-'s Avatar
If your truck came witht he tow package, you do have a 7 pin connector.. Leke the others said you will have to add your own brake controller..
Old Sep 15, 2006 | 09:33 PM
shtrdave's Avatar
Thanks, I'll pick pne up at work Monday. The harness is in the drivers door panel, I remember seeing it.
