Ok silly question for some.
Old Sep 4, 2006 | 02:27 PM
cpu77's Avatar
What Rear end front end does my 2005 SXT 4x4 have? Is it a Dana 60 What are they? I want to do a gear swap and convert my lug pattern to 8x170 so I can run some wheels I want. I figure custom axles would be the best way to go.
Ralph
Old Sep 4, 2006 | 02:30 PM
04procompLARIAT's Avatar
It would be a Ford 9.75 inch rear end. Not a Dana 60. You would be better off just finding the wheels with the 6.135mm lug pattern.
Old Sep 4, 2006 | 02:40 PM
cpu77's Avatar
Why? Because of expense? I will already be in there for the gears
Old Sep 4, 2006 | 02:59 PM
Quintin's Avatar
An STX will have an 8.8" axle, only the 5.4 liter trucks get the 9.75".
Old Sep 4, 2006 | 03:02 PM
ThumperMX113's Avatar
So what are you planning on doing with the front? SFA swap?
Old Sep 4, 2006 | 03:05 PM
Josiah's Avatar
I hope you thought this out because finding the lug pattern to swap that ifs front end diff is going to narrow it quite a bit, mounts will need to be made as well. A SAS is not too far down the path. I would definitely stick with the 6x135 pattern if I was lowered (sas will do you no good).
Old Sep 4, 2006 | 03:11 PM
cpu77's Avatar
I have not looked at the front. The rear is easy custom axles are cheap. The front is alittle more difficult. I need to look at the front end. I haven't had the truck long. I guess I could just use wheel adapters though!
Old Sep 4, 2006 | 03:41 PM
I don't see the point, why not just buy wheels for the 6x135 lug pattern?
You're making things way more difficult than they need to be, plus wheel adapters? :santa:
