Ford spark plug tool??
Old May 10, 2007 | 08:39 AM
  #46
dbhost's Avatar
Originally Posted by kd4crs
I have read accounts on several truck sites that have gone both ways. Some dealers have covered the problem while others stuck the customer for the full bill. I guess it depends on the dealer.
And the customer's willingness to involve the courts. Effectively, the dealer busted the vehicle while in their custody. They SHOULD foot the bill.
Old May 10, 2007 | 09:32 AM
  #47
aussie-revhead's Avatar
The TSB is shown in this thread at post #21 .
Old May 10, 2007 | 11:42 AM
  #48
pkp190's Avatar
I just may be blind but I never saw it stated is this only for the 04 or is it for all model years after 04. Thanks
Old May 10, 2007 | 12:21 PM
  #49
MGDfan's Avatar
Hi. It's okay - the whole issue is confusing... it's the 04 & up (to 07) 5.4L 3V modulars, and the 4.6L 3V modulars in the new 'stangs.
I'm waiting to see if the issue is addressed in the '08's ....
Old Jan 16, 2009 | 02:46 PM
  #50
cmharshey's Avatar
Smile Removal Tool
I have a 04 f150 and when i changed the plugs three of the eight broke off with the porcelain and the the little pin still in the head. I had to take the pin out with pliers, and use the spark plug removal tool. Its fairly cheap and easy to use, it pushes the porcelain down enough to get the other removal tool into the metal part and it comes right out! Its about a hundred dollars, alot cheaper than the one from ford!
This is where i found the tool and i had no problem with it!
Dixon Racing Supply
Old Nov 11, 2010 | 05:36 PM
  #51
yeloufo's Avatar
Thumbs up tool for removing broken plugs
You can find the tool at amazon.com for 60.00 some dollars instead of 100.00
Old Nov 11, 2010 | 06:05 PM
  #52
sam1947's Avatar
I understand this is your first post TIP: Check the date of the last posting..this one is almost 2 yrs old...just a 'heads up'
Old Feb 29, 2012 | 09:01 PM
  #53
donobull's Avatar
why do you want to replace spark plugs at 45/60000 thousand miles. the plugs are 100,000 mile plugs. my vehicle has 75,000 miles and the spark plugs are doing fine. so if you follow the recommended maintance schudule,you will be find.
Old Mar 1, 2012 | 09:05 AM
  #54
They do the early plug change to try to avoid the plug breakage problem. Get them out before too much carbon builds up. However, I think there are better options.
Old Mar 1, 2012 | 01:46 PM
  #55
Ford has changed the recommendation on the 3v to 60k.
Old Mar 2, 2012 | 06:18 AM
  #56
rman550's Avatar
google the Lisle spark plug remover tool part number 65600. Works great on the 3 valve broken plugs!
