Remote Start
Old Aug 13, 2006 | 10:50 PM
okstategrad2002's Avatar
Remote Start
Has anyone bought the Ford factory remote start and added it to their truck? Im curious as to the quality.
Old Aug 13, 2006 | 11:18 PM
ericd's Avatar
Yep - I installed the Ford Gold system (remote start and alarm) last year. Couldn't be happier with it.
My only complaint setting the sensitivity of the shock sensor for the alarm. It seems to be all or nothing for some reason. Either the alarm goes off if the wind blows the wrong way, or you can beat the truck down with a sledge and get nothing...I don't blame the unit for that though. I think it has something to do with where and how I mounted it.
Other than that, it's been flawless since day one.
E...
Old Aug 13, 2006 | 11:19 PM
SteveVFX4's Avatar
I've had mine for over 2 years, not a single problem with it. Usually what is more important with any system is the "quality" of the installation!
Old Aug 13, 2006 | 11:26 PM
azmidget91's Avatar
where can i find this ive wanted an alarm/remote start
Old Aug 13, 2006 | 11:30 PM
whitecrystal1's Avatar
I've seen them on ebay new for $150.
Old Aug 13, 2006 | 11:31 PM
F150Truck'in's Avatar
E...
I have the same system with the same problem, I think it where I mounted the brain, it said not to mount it anything solid, to mount it to a big wiring harness... I zip tied it to the steering wheel column suport... it goes off everytime I park in direct sun on a hot day, just lowered the settings on it today....
Yes , I highly recommend this system, just don't mount the brain to anything solid...
Old Aug 13, 2006 | 11:32 PM
Thats great to hear. I was looking at aftermarket systems...but realized I didnt want to carry 2 remotes all the time. How much did the dealer charge you for install, or did you do it yourself? I installed a factory alarm/keyless entry myself in my 99 F-150. Lots of wires...is any part of the gold system plug and play?
Old Aug 13, 2006 | 11:43 PM
I installed it myself...
look here and it all the info you need....
http://www.gemsen.com/ford/
look at
'02-'06 ITRM Base
'02-'06 ITRM Trucks
RMST-RKE-VSS
Old Aug 13, 2006 | 11:49 PM
If I'm not mistaken. You get two new remotes with the kit and they take place of the factory remote. It will still work but not the alarm. I had the viper 791vx installed in mine and it's the only remote I carry.
Old Aug 13, 2006 | 11:51 PM
ericd's Avatar
look at
'02-'06 ITRM Base
'02-'06 ITRM Trucks
RMST-RKE-VSS
Same here (self-install). Also used the same site to download the instructions. There isn't much of anything I remember being plug and play. I think after it was all said in done, for the options I installed, I ended up splicing 30+ wires in the truck. Took a solid day to complete because every connection was done by the book (Wire cut, splice soldered in, covered with adhesive-lined heat shrink, etc.).
F150Truck'in - What you mentioned the mounting makes sense - Mine is on a solid surface also (firewall). Maybe I should try to move it for better results.
I bought mine through eBay. Don't remember the price but it was one helluva deal.
E...
Old Aug 13, 2006 | 11:54 PM
You get 2 new 4 button remotes and don't need the factory remotes at all....
you can still use the factory remote if needed, they will arm and disarm the system with lock and unlock, but wiil not start the truck... no button for that..
Old Aug 13, 2006 | 11:58 PM
Since you mentioned the mounting, mine is on a solid surface also (firewall). Maybe I should try to move it for better results.
E...
I just turned down the setting today, if that don't work then i'll move it...
BTW: I sent you a PM on the that peice of metal a few minite ago, did you get it...??
Old Aug 14, 2006 | 12:02 AM
ericd's Avatar
I've been all over the chart with sensitivity, without much luck. I always had a hunch that it had something to do with mounting.
PM replied to...
E...
Old Aug 14, 2006 | 12:10 AM
PM replied to...
E...
I also followed the install, soldered all connections, but insteed of mounting as stated, I solid mounted, as I have all system I've installed.. but the differance is the shock sensor is interial... I did'nt think about that.. i'm quite sure i'll be remounting it.....
BTW: thanks for the drawing, I'll be looking for it...
Old Aug 14, 2006 | 12:17 AM
Thanks for the info fellas, one last question: Ive got the electronic temp controls. It seems to default to auto mode. Is there anyway to get it to stay on defrost mode? What about heated seats, I think they also default to off once the truck is turned off.
