A/C recirculation defaults to "off"?
Old Jul 17, 2006 | 04:13 PM
DJR 17's Avatar
All I know is if I get in the truck and sit there writing up an invoice, if I set it on anything but full auto it won't cool properly until I start moving. This can't be right? It seems like its maybe cutting out on high pressure or something.
Old Jul 17, 2006 | 04:16 PM
AirborneRacer's Avatar
My FX4 does the same thing so I guess its an across the board deal. Oh well I would rather have to do that then have no air at all .
Old Jul 17, 2006 | 04:18 PM
gobra's Avatar
Mine used to do that and it ticked me off but I had my processor reflashed for rough idle and it hasnt done it since. I dont know if the reflash fixed this, but my recirc has NEVER gone off since. xlt and manual controls.
Old Jul 17, 2006 | 05:16 PM
ThumperMX113's Avatar
HAH! My 2006 doesn't do that. My 2004 did and it would annoy the hell out of me!
Old Jul 17, 2006 | 05:24 PM
Kris10's Avatar
my 2005 FX4 does the same damn thing..
Old Jul 17, 2006 | 05:25 PM
SSpiro's Avatar
Originally Posted by SSpiro
I'll have to try it, but I didn't think that when Auto was pushed the recirculation came on?
Well, tried this on the way home and didn't work. I had to manually press the recirculate button..
Old Jul 17, 2006 | 06:00 PM
blkscrew's Avatar
Originally Posted by TruBluSuperCrew
This is what the manual says:
4. Recirculation control : Press to activate/deactivate air
recirculation in cabin. Recirculated air may reduce the amount of time to
cool down the interior of the vehicle and may also help reduce undesired
odors from reaching the interior of the vehicle. Recirculation engages
automatically with selection of MAX A/C
or can be engaged manually in
any other airflow selection except defrost. Recirculation may turn off
automatically in all airflow selections except MAX A/C.
doesn't work that way on my 04 Lariat screw....and when I took it back and complained about the not so cool A/C....the techie say's....be sure and always hit the recirc button to cool it off quicker....
I can relate....mine doesn't really cool till I hit the freeway....about 15/20 minutes from work....stop and go traffic and it's mediocore @ best....might as well not turn it on till I hit the freeway...only complaint I have with this truck....hopefully e-fans will help....their sitting in the foryer as I type this...UPS man just left .....prolly be a week or two till I get them in though hot as h e double l here today....
Old Jul 17, 2006 | 06:51 PM
Quintin's Avatar
Mine does, especially if it's really hot outside. The system will do whatever it can to cool the cabin to the desired temperature as soon as possible, and that's easier to do on recirculate.
Old Jul 18, 2006 | 12:53 AM
Nates06SCab's Avatar
I've figured out that the Auto setting DOES recirculate as needed. When it's blowing hardest it IS recirculating. Relax, and enjoy the auto you paid for.
Old Jul 18, 2006 | 01:14 AM
Nike2196's Avatar
In my STX, whenever i have on Max AC the recirculate button is lit up.
Old Jul 18, 2006 | 02:11 AM
kcward's Avatar
My Lariat does it! When using the re-circ setting with the defroster it will revert to normal after a period of time. Had it happen while driving through a snow storm in Lake Tahoe this past winter. I had to pull over when the windows fogged up...pushed re-circ again...window cleared again after a few minutes. Real pain!
Regards!
Old Jul 18, 2006 | 02:49 AM
sterusmall's Avatar
AUTO or not, the recirc button needs to pushed everytime you turn the key on. And when the heater is on, it will kick off for no reason and if your behind a deisel (semi truck) it stinks up your cabin and you know that the recirc just shut off.
Had my truck for a year and a half now and my only real complaint is that the A/C sucks and the controls for it suck.
Old Jul 18, 2006 | 08:14 AM
ckforker's Avatar
I took my truck in yesterday because on "Auto" it would not go into re-circ. They said that the whole switch module needed to be replaced.
Old Jul 18, 2006 | 08:23 AM
jpdadeo's Avatar
My EATC works great, I never take it off auto. The only time I hit the re-circulate button manually is when I don’t want the outside air in the cabin for one reason or another (dust, stink, etc)
On startup, if it’s really hot in the cabin the EATC will automatically go to re-circulate after about 2 to 4 min. When I manually click it on it will stay on about 15 to 20 min before turning itself off
Old Jul 18, 2006 | 08:28 AM
DJR 17's Avatar
Does anyone know if these trucks have a high pressure switch? My compressor will turn off sometimes when I just start the truck and sit idling. The coldest it'll blow is 42 degrees so I don't think it's low.
