Hyperactive blinker problem...
I posted this before but I am curious on if this has happend to anyone else? When I turn on my left blinker it blinks really fast and I hear a buzzing sound coming from my dash area everytime it blinks. But when I put on my right blinker everything is cool. And when I put my hazards on everything blinks good. Anyone know what this could be? I do have APC led tails but they have built in resistors in them. I am confused!!
I just fixed mine. It had been doing it for a while. My brake light on my left side burnt out..
The fast blinking is its way of letting you know one of the blubs on the left side of the truck is burnt out..
Originally Posted by 04procompLARIAT
Oh come on guys...I know this. Both my lights work fine. I have no idea whats going on here! I guess ill just have to take it in and put my stock tails back on for a bit.
I had the same exact problem back about a year ago. I finally took it in to the Dealer. Turned out to be a bad Turn signal switch assembly. They swapped it out and I had no further problems with it.
My guess would be either a bad multifunction switch, but since there is a buzzing noise from under the dash that leads me to believe it is the flasher it's a little round silver part that is under the dash it has 3 square prongs. Usually when you get the buzzing it means a bad flasher, it may not be, but it's a cheap and easy place to start. And i'm all about working smarter not harder lol
Yeah, I said this once before in your last post. When I put in my LED's and before I put the resistors in, I tried the signal and it would BUZZ and blink really fast. I believe I suspected the APC tails last time for a faulty resistor...Glad you got it fixed!
