EDGE WOT Shift Points
Old Apr 30, 2006 | 09:54 PM
Verado300's Avatar
I have my 1-2 and 2-3 shift points set to 5300rpm, 3-4 @ 4900rpm, and WOT fuel at 1.5..... just wanting to get feedback from others WOT shift settings, i dont want to over rev the motor .......My limiter is either at 5450 or 5500, i cant remember... This is becasue i think it said the rev limiter had to be at least 150 rpm over the highest shift point.....My firmness is set to 5 on 1-2 and 2-3 and 0 on the 3-4 shifts.....BTW i am running level 2 becasue i dont want to pay for high test.....EDGE WITH 4.56 = ....i have mad belt sqeal... gatorback is next....
Old Apr 30, 2006 | 10:19 PM
cobraman302's Avatar
What kind of 0-60 times were you getting before the 4.56 gears, and now after the 4.56's? I was looking into getting some 4.56 gears also. Those WOT shift points are fine, tahts close to what I have mine set at. I think I actually have mine set to 5250 on 1-2, 2-3 shifts, and 4900 on 3-4 shift, with a Rev set at 5600. I can only imagine your belt squeeling, mine does it with 3.55's.
Old Apr 30, 2006 | 10:50 PM
Verado300's Avatar
I dont know my previous 0-60 times, i have a screw with 33's and before with 3.55's it was really bad.... like a big slug...probably 10.5-11.5 seconds to 60...now its 8.9 with the gears, tuner, exhaust, and airaid jr w/ K&N... Its is a huge diffrence.... be careful on the edge 0-60 tho becasue if your speed is not right on at 60 your times are going to be way off...For example i was 3 mph off the first 0-60 run and it said i was running a 10 sec 0-60 when really it was between 8.9 and 9.2, after setting speed by changing tire size using the GPS..... i am not concerned with 0-60 its a heavy truck... i know it hauls tail tho....
Old Apr 30, 2006 | 11:17 PM
Josiah's Avatar
You must be in a 4.6L.
Old May 1, 2006 | 12:13 AM
Verado300's Avatar
NO 5.4 3v..... i just think everyone over exagerates or talks about incorrect 0-60 from there edge....my truck probably at the most has 270RWHP, and in a 6400 lb truck you will not go to 60 in 6.5 seconds..... my old 300zx would hardly get to 60 in 6.5 sec...
Old May 1, 2006 | 12:19 AM
anaheim_drew's Avatar
What was wrong with your 300zx?
Old May 1, 2006 | 12:23 AM
Josiah's Avatar
I'd say 270rwhp might be right, I am at 270rwhp with my mods. I wonder if he's at a high elevation, thats the only way I can explain his extremely high 0-60's. Thats a huge assumption to make (being everyone is lying about their 0-60's).
Old May 1, 2006 | 12:27 AM
Verado300's Avatar
No i am in Daytona Beach Fl 32' above sea level...you are probably right ... i wouldnt be suprized to only have 250 rwhp ... and thats what i am saying....with those numbers my 0-60 is right..... high 8's...
Old May 1, 2006 | 12:30 AM
I deleted what I said. Sorry if I offended you..... How do you like your 4.56's?
Verado300's Avatar
I am not saying everone is lying.... but a regualr cab short bed with the same mods, with stock tires is going to be a 2 sec diffrence from a SCEW with heavy off road tires. The 0-60 might range from high 6's to high 8's....BTW what do you think about the WOT shift points hahaha... didnt mean to start anything!
Old May 1, 2006 | 12:35 AM
Verado300's Avatar
4.56's are great... low end rocks but with the 33's at 75 i am @ 2500 rpm, slightly high....But its a great reason to lift it and go to 35's once these tires are worn out I dont regret geting 4.56's, it is to much money to just get 4.10's unless you are going to run stock or close to stock tire sizes......If i had 3.73's i would have never got gears, was a big mistake to get 3.55's when i bought the truck new.
Old May 1, 2006 | 12:36 AM
Verado300's Avatar
It was not a TURBO it was N/A! only like 220 crank hp... not close to that dyno!
Old May 1, 2006 | 02:48 PM
Well I definately dont have a reason to lie about my 0-60 times, its at 6.8-6.9 all day long. Ad I triple check my gear size and tire size everytime I do a run. Stock was right at 9 seconds though. I think that I would go through a set of tires very 6 months if I had 4.56 gears though. These times are with edge, exhaust, and intake on an 06 xlt 4x4 supercab 5.4.
Old May 1, 2006 | 11:01 PM
Verado300's Avatar
i think the tires are the real killers.... the extra weight even with 33's is a big deal....yea with your HP figures i am probably around the same, and with the tires and added weight of a screw, my 8's are probably right....
Old May 1, 2006 | 11:05 PM
Josiah's Avatar
I hardly lost .3 seconds or so off my 0-60 going from 32's to 37's, but I was running around 8's on 32's even with all my mods lately, I hit high 6's at one point before a couple mods, hard to explain but it seems I lost a little power over time. I need to get an edge so I can get accurate means of doing so, but regardless the means I used to time before the 37's was the same as now, and it is not a variable in my times, I could have been running 7.3's and am now running 7.6's, but the difference from going from my 32's to 37's is not a big deal, maybe it is when you're not well modded, I don't know. If you doubt me we'll have some sand drags @ Pismo and everyone can come back and tell you different
I'll take a few members for a ride on the street so they can vouch for me, it's still not slow. The only thing that might be a variable is if Nitto's numbers are wrong and their tire revolutions per mile are off a little, but I doubt thats the case. If it is then I'm reading slower or faster than I'm really going (if anything it's too low of a number so I should be running faster which would equal a quicker 0-60).
