Josiah, i need help!!
If I remember correctly you had a grinding noise in the front end of your truck when you put it in 4wd. Did you ever figure out what it was and how did you fix it?
I am getting a really bad grinding noise when I put mine in 4wd and its only since the lift was put on.
What is IWE?
It is a bellow that has a gear attached to it which slides back and forth. when vacuum is applied to the bellow it retracts the gear which disconnectd the outter hub from the half shafts and connects when vacuum is removed.
With the grinding noise, Your frint drive shaft might be install backwards the end with the boot should be connected to the trans case (I think).
Originally Posted by Ayresusn
Intergrated wheel end
I never took the drive shaft off the truck so I dont think thats the prob. Hope I can figure this out soon.
no it wasnt, I put the lift on
since you did you lift your self, the IWE's are the part that bolts to the inside of your steering knuckles that has a rubber hose connected to it with two ports on it.
Hope everything works out for you with grinding noise, I had a few problems with 4wd after i put mine lift on (but it was only when it was in a bind(the backend buiried)) but afterr going through everything found nothing wronge and it works now.
My bad, I removed mine when I put my lift on. How is it working out with out rekeying the front drive shaft, this might be causing a little binding problem.
Front drive shaft has really bad vibrations, I will get it fixed up as soon as I get the money. Hope that takes care of some of the probs.
I know fabtech sells "May experience driveline vibration in 4WD at high speed. Order FTS92000 CV Front Driveshaft for extended high speed use." that is from their website.
