Mounting a new center console
I am in the process of replacing my jumper seat with a console (either flo thru or xlt) and I need to know if the mounting on these will be the same as my seat? please reply asap thanks in advance
As I understand it, the XLT console is a direct fit. I'm not too sure on the FX/Lariat console, I think there is a bracket on the bottom that uses different mounting holes than the front center seat holes, the console holes are closer to the dash. Someone correct me if I'm wrong on that.
you will still use the same 4 bolt holes/studs. You can also check out the below thread
https://www.f150online.com/forums/sh...ight=flow+thru
or take a look at this thread
https://www.f150online.com/forums/sh...d.php?t=216615
FX4andHARLEY put one in a regular cab, and made the shifter work. he has some very good instructions and step by step pics
Originally Posted by 4RDFMLY
Is it a reqirment to have the floor shifter if you have the XLT with the optional captains chairs or is there a different console when the XLT doesnt have the floor shifter.
