2" vs 2.5" on a 2wd
2" vs 2.5" on a 2wd
Due to the relatively lower front coil springs on a 2wd truck will it take a 2.5" Autospring spacer to sit level rather than a 2 inch spacer that makes four wheel drive trucks sit level?
I really don't like the front sitting higher than the back, but I also don't want to put a 33" tire on and find out that because my coil springs are shorter than a 4wd that I needed the 2.5".
Any help from you fellow 2wd drive guys that have an AS spacer would be greatly appreciated.
I have a 2wd supercab, and I'm sitting on the 2.5. I had the exact same issues when I was deciding which to go with, but I am 100% satisfied with the 2.5. It sits perfectly level, rides like stock, and looks great.
My 2 cents- 2.5
My 2 cents- 2.5
My 2 cents- 2.5
My 2 cents- 2.5
Pics?
And would I just order the Fx4 block from Ford?
This is whats on it, Tires 325/60r18 Nitto Terra Grapplers, wheels are Black Helo Maxx6 18x9.
