New Updates Available for Edge
Originally Posted by ThumperMX113
Im glad I don't have any shudder. .
. . which leads me to believe this is not an Edge related problem.
Anyways, what is the correct size in mm for a 35" tire? Edge list it as 2792 but that tire calculator gave me something different.
. . which leads me to believe this is not an Edge related problem. Anyways, what is the correct size in mm for a 35" tire? Edge list it as 2792 but that tire calculator gave me something different.
I also checked this with a handheld GPS and it was within a mph of what the edge said.. (my speedo shows about 2 mph faster than the edge though)
Yeah, I'm freakin baffled -
This morning my RPM's were running around 2200ish @ 74 MPH as previously stated....
On my way home I GPS'd myself with the custom level 3 tune I've been running a for a few days. Edge was off by about 2-3 MPH. Pulled over and reset the Edge to just run on regular level 3 program - GPS was dead on and my RPM's back to 2090's - 2100ish @ 74 as they have been in the past. Only thing that I can guess would be wrong is the what the rest of the guys stated about incorrect tire size.....I have also lost a couple MPG and the shuddering occurred this morning again around 50 MPH, RPM's were bogging, etc.....Looks like its back to Edge level 2 until this fiasco is taken care of.
Thanks for everyones input thus far
On my way home I GPS'd myself with the custom level 3 tune I've been running a for a few days. Edge was off by about 2-3 MPH. Pulled over and reset the Edge to just run on regular level 3 program - GPS was dead on and my RPM's back to 2090's - 2100ish @ 74 as they have been in the past. Only thing that I can guess would be wrong is the what the rest of the guys stated about incorrect tire size.....I have also lost a couple MPG and the shuddering occurred this morning again around 50 MPH, RPM's were bogging, etc.....Looks like its back to Edge level 2 until this fiasco is taken care of.Thanks for everyones input thus far
Just a little up date on my little tire/speedo problem. I went through and redid my lvl3 programming, then went out with the gps again. According to Edge my 325/60/18's are supposed to be something like 2660mm. I set it to this and at 60 mph I was again off 5 mph. So after doing a bunch of playing with different sizes, I finally have it set on 2520mm and the Edge is right on with my garmin gps. And the speedo must be right this time, because this morning I was going to town, I had the cruise set at 60 mph and a state trooper was going the other direction. He went past me and the car that was behind me (about 1/4 mile), but the 3rd car (about 1/2 mile behind) got pulled over. So I figure that was a pretty good test....
Paul
Paul
Originally Posted by mkinttrim
Got stock 255/17's on mine and edge has it as 2550mm for tire size, went to
http://www.1010tires.com/TireSizeCal...?action=submit and put in my tire size and they came up with 2477.5 mm. Which is right?
I changed mine to that but the unit reverts back to 2480 for some reason, will take it out of the truck and do the custom tune tonight. Its running 2-3 mph lower than the speedo.
Bill explains that Ford speedo is off by 1-2 mph (Edge being correct):
Okay, one quick word about the speedometer. Well, maybe not so quick. The speedometer and the Evolution get their signal from the exact same place... the PCM. On practically every truck we've tested (regardless of tire size / gear ratio setting) the speedometer reads 1-2 MPH higher than the value coming from the PCM (and subsequently the Evolution). Given the analog nature of the speedometer, we just accept this as normal. We have speed tested with both our Dyno and a GPS and have been dead on with the Evolution MPH while the speedometer is 1-2 MPH high (always high for some strange reason). Even the factory scan tool indicates a discrepancy. However, the odometer being digital does read out correctly despite the variance in the speedometer. Again, it all falls back to setting tire size and gear ratio correctly.
Copy of link to quote above:
https://www.f150online.com/forums/sh...97#post2008697
