New Updates Available for Edge
Old Apr 6, 2006 | 01:12 PM
  #46
Y2KWHT150's Avatar
Had my update last night, drove my truck this morning to work...first thing I've noticed is that I no longer have that drone notice/feel around 45-60 mph. The shudder I was having is gone also. Finally, transmission seems to shift smoother than before although no difference in performance gain or lost. Over all I am somewhat impressed over the last update. BTW, my truck is from RXAQ family.
Old Apr 6, 2006 | 05:30 PM
  #47
PHS79's Avatar
I still have the orginal version that mine came with, which is either 13 or14. I have been running lvl 3 for well over 1.5 months now and no problems with driveabilty (sp?), the only issue that I noticed is that the speedo (on the evo) was off 6 mph conpaired to my gps when I did a custom setting for my 325/60/18's, and this would explain the reason why I was getting passed and not the one doing the passing. The truck speedo said 60, evo said 59, gps said 53. I ended up having to set the evo to the stock size tire in order to get the evo to read the same as the gps did. Would the new update help with this at all??
Paul
Old Apr 6, 2006 | 05:34 PM
  #48
expy03's Avatar
Paul
Did you change the rear gear setting?
Old Apr 6, 2006 | 05:49 PM
  #49
PHS79's Avatar
Nope, it was set to 3.73 which is what my truck has.
Old Apr 6, 2006 | 06:15 PM
  #50
jims94vmx's Avatar
how is it off light throttle? i have always had some sort of lunge if you will....nothing noticable when giving it more gas, just real light throttle from a dead stop.....
Old Apr 6, 2006 | 06:25 PM
  #51
Kool Aid's Avatar
When you checked it it said 3:73, but that's not what was in the tune. When you look at it, you need to hit the enter button, and not just back out of that section.
This is what this latest update is supposed to fix. You can look at it, and it will show the 'actual' gears that the computer is tuned for, not the default number that showed up on the screen.
Old Apr 6, 2006 | 08:53 PM
  #52
luke04f150sc's Avatar
Hex: RXAQ5B4 Updated and also had no problems. I never had the shutter problem that others have had on level 3. I really haven't noticed a difference from level 2 to 3, except for maybe a loss of low end torque on level 3.
Old Apr 6, 2006 | 08:55 PM
  #53
04NickySP2's Avatar
According to the update notes you should now feel a difference between lvl 2 and 3. I know I did but the shudder still has not been fixed.
Old Apr 6, 2006 | 09:54 PM
  #54
Doo2theSea's Avatar
Originally Posted by 05supercrew
same hex code here. I just uploaded the new update and on level#2 and it works good. Only drove about 15 miles. Tomorrow I will do about 100 miles. Truck still running good.
Interesting we have the same HEX
Drove a few hundred miles last night on level 2 and all seems well. Going to fill up with 93 tomorrow and try level 3. Hope things are better with it.
Old Apr 7, 2006 | 06:22 AM
  #55
jims94vmx's Avatar
hey guys, when doing the update, is it a large file? i went into the lightning software and hit check for updates and it was 10.1 in size....that right? isn't that the size of the whole program? just making sure i am doing it right....thanks.
Old Apr 7, 2006 | 08:53 AM
  #56
05supercrew's Avatar
Let me know how level 3 works out, I havent tried it yet. From what I hear it works good.
Old Apr 7, 2006 | 09:09 AM
  #57
BBIC_Strait's Avatar
It will give you a new version of the Lightning software, along with the firmware and calibration. That is the correct size.
Old Apr 7, 2006 | 10:08 AM
  #58
F150 Duke's Avatar
So are you guys on version 1,000 or 1,001? Sorry, couldn't help it, I just see more updates come out for this thing to fix problems then I do Mircosoft XP.
Duke
Old Apr 7, 2006 | 11:18 AM
  #59
Kool Aid's Avatar
Duke
You make it sound like a bad thing.
Why?
I would much rather have them update, then do nothing like some other brands.
We ask the Edge people for improvements, and they listen..... and provide.
What a great company.
Old Apr 7, 2006 | 11:27 AM
  #60
mkinttrim's Avatar
Yep, sure is better than sending it back to the Tuner Gods
