Fabtech 6" Installed, LOSING CV BEARINGS!
Originally Posted by Quintin
I think someone's jerking with you. Those are way too small to be bearings to the CV axles, and you can't get those bearings out of the axle without completely disassembling it. They don't just fall out without you knowing.
Originally Posted by deerfeedrb
I know this may sounds stupid, but did they have grease on them when you found them?
http://www.4wheeloffroad.com/techart...131_0509_ford/
Check out the photo and part about over extended cv joints, shows a good example of where the bearings came from.
Originally Posted by ThumperMX113
So, whats the noise?
Originally Posted by baja150
Well where do you think they could be from?
Where else COULD they have come from?
I agree the ***** are too small to be from CV joints, so what else is in the front end that would have small, loose bearings? Are there any kind of ***** in the Integrated Wheel End - like a ball ramp clutch? If they fell out of an IWE then that might explain the noise . . . . .
Turns out my front driveshaft is spinning in 2wd along with the halfshafts. My vacuum lines are connected to the 2 prongs sticking out of the steering knuckle, so what gives.
Those are your muffler bearings Josiah.. they must have fallen out when you did the Magnaflow to Flowmaster swap....
Sorry, just had to interject a little humor into a situation that would have me putting a wrench through my garage wall.
Now that I've seen them up against the coins I agree that if they are CV bearings then they're the smallest ones I've ever seen; those are usually like 1" or so in diameter.
It just doesn't make sense to me where the sound could be coming from while driving. The only thing turning when there's no vacuum to the PVH's is the front and rear driveshaft which both have U-joints on both ends and the front axle shafts which have CV joints.
I admit that they are small, very small, but I'm sticking with the thought that they're from the CV joints. It just seems like too much of a coincidence that there's 12 of them and there's something making noises while rotating.
There were only 12 right? No more no less... are you sure?
Is the engine running?
Still only found 12.
