Undercover maintenance?
Hey folks, a search for this topic came up fruitless, so here goes.
Is there any minor maintenance that is suggested for the Undercover? I have had mine on for about 8 or 9 months now, and am wondering if there is anything I should do to the hydraulic arms or hinges or anything.
Thoughts?
Thoughts?
Thoughts?
Thoughts?
Thoughts?
Thoughts?
The locking mechanisms of your UNDERCOVER require only periodic lubrications with lithium grease. Do not use penetrating oils as they will attract dirt and dust. Wipe any excess lubricant off of the surface of your UNDERCOVER.
The gas operated lift strut shafts are self lubricating and should only be cleaned periodically with a damp cloth. No solvents or lubricants should be used on the strut shafts, as this will cause premature seal failure of the strut.
All installation hardware and fasteners must be checked periodically for tightness as vibrations from normal use could cause loosening.
Hope this helps.
