smell gas!!!
Old Mar 17, 2006 | 04:28 PM
YOMAN's Avatar
smell gas!!!
sometime i hopped in my truck 04 FX4 and started up, i could smell GAS inside the cab then it disappeared in 2 min or so...what the heck is that or where the heck is that comng from????
Have this happen to you ??
Thanks!
YOMAN!
Old Mar 17, 2006 | 04:29 PM
JJG052590's Avatar
Banned
Hmmm never happened to me, but doesn't sound good. Could you have spilled some or something? Or gotten it on your shoe?
Old Mar 17, 2006 | 04:30 PM
oops, I thought this thread had something to do with Raoul. Sorry.
Old Mar 17, 2006 | 04:32 PM
YOMAN's Avatar
Nope...nothing spill or ANYTHING but it doesnt happen often.. i said once a while in a month.. maybe 2x in a month. I m guessing that i left vent heat or ac on when not use truck.. then start up it sucks air from outside into cab..i dont know..
YOMAN!
Old Mar 17, 2006 | 04:44 PM
JJG052590's Avatar
Banned
Still seems extremely od.
Old Mar 18, 2006 | 10:27 AM
Tbird69's Avatar
I had a similar thing. Every now and again I would smell gas when I would start 'er up. It would happen after refueling now and again as well. It turned out to be a crack in the metal part of the fuel line that goes from the filter to the fuel rail. My dealer found it when I had the truck in for #3 service. The cool part was I hadn't said anything about it, they found it, fixed it, and told me after. It was all covered by warranty of course. Without warranty it would have cost me around $400 to fix it.
Old Mar 22, 2006 | 10:34 AM
nu-supercrew's Avatar
Thanks!
YOMAN!
That has been happening to me for the last 5000 miles or so...
https://www.f150online.com/forums/sh...85#post2079485
Old Mar 22, 2006 | 11:13 AM
kapoho's Avatar
What part of the metal line was the crack on? I haven't even looked yet, so excuse my igonorance if it is extreemly obvious; I have about of foot of snow on the ground right now and do not want to crawl under the truck if I don't have to.
My truck has a gas oder from the vents whenever I am stopped. When I am moving or if the vents are closed, the smell goes away. This is driving me crazy and your fix may hopefully be my solution.
Old Mar 22, 2006 | 02:04 PM
Tbird69's Avatar
I'm not trying to sound any alarm bells, this was the problem on my truck. It may be a different issue on yours. Best thing to do is take it in and have it looked at, fuel odour/leaks are not to be taken lightly. Whatever the problem warranty covers it (assuming you still have warranty).
Old Mar 22, 2006 | 02:13 PM
05supercrew's Avatar
I delt with this in another truck on filling the tank there was a seal in the tank that was loose and would let some fuel splash out of the tank where the filler neck meets.
Old Mar 22, 2006 | 04:37 PM
FordWask's Avatar
Apples to Oranges I know..
I had a 78 Mustang, similiar issue...
Just dropped my girlfriend off, driving in the middle of town and all of the sudden my Mustang turned into a bonfire...
Needless to say... get that smell checked out!
Old Mar 22, 2006 | 04:41 PM
JJG052590's Avatar
Banned
Did you get it checked out or what?
Old Mar 22, 2006 | 06:50 PM
Yeah TBird, what part of the fuel line?
Kapoho, let me know what you find, and I'll do the same.
Old Apr 8, 2006 | 12:15 PM
Smokeneck's Avatar
I've noticed the same strong smell of gas a couple of times in the past. I pulled into a Home Depot Thursday and smelled gas pretty strong after shutting the truck off. I had filled the tank earlier but had driven close to 60 miles since then. Probably should take it in for a check over.
