help engine problems
Old Apr 8, 2006 | 01:06 PM
wakebordlf's Avatar
i need some help, whenever i get on the gas pedal my truck gets to about the shift point my rpms act like i'm at the rev limiter going up and down almost like i am low or have no gas, this has happened at differant rpm's like 3000 and 7000 depending on which gear i am in
i am currently waiting for my superchips tune to go back to stock from my performance tune maybe thats the problem?
Old Apr 8, 2006 | 01:30 PM
ChrisAdams's Avatar
Return it to stock tune to eliminate the possibility of it being a bad tune. If it still does it, assume it is either the fuel filter clogged, bad fuel, or you are losing the fuel pump. That's from your short description.
Chris
