Coolent, transmission temps
Old Mar 5, 2006 | 01:01 AM
drz400dp's Avatar
I just got a edge and have been watching my water temps and transmission fluid temps. My water temps seems to stay at 194, and my transmisson varies between 134 and 146. Transmission seemed hot to me since it is the dead of winter. Outside temps are about 50 or so here in california. Do these temps seem normal to what the rest of you with edge are seeing.
Old Mar 5, 2006 | 01:05 AM
billindenver's Avatar
Coolant and tranny temps are two that I monitor as well. Tranny in the 150 range (lots of hills here) and coolant between 192 and 196.
Bill
Old Mar 5, 2006 | 01:21 AM
countyboy04's Avatar
My trans temp. concerns me. It usually runs between 160 and 170. Is this to high?
Old Mar 5, 2006 | 01:46 AM
drz400dp's Avatar
your transmission seems warm to me, but then again you live in quite a bit warmer climate than i do. maybe someone will chime in that knows whats a acceptable temp range for these transmissions.
Old Mar 5, 2006 | 01:47 AM
kd4crs's Avatar
150 to 180 on the tranny temp is normal. The factory trans cooler doesn't start cooling until 185.
Old Mar 5, 2006 | 03:06 AM
bushtree's Avatar
140-180 would be normall for the tranny. Start to look out when you tranny temp climbs up to 200F (Usally only when towing or offroading)
Engine coolant will range between 192-198 usally. It will raise as higher with high rpms. Dont worry about it untell you start to see temps in the 215+ range..
Old Mar 5, 2006 | 05:18 AM
05RoushMarkLT's Avatar
What is involved with hooking up a tranny temp gauge? Is this something I can do in a couple hours of work? I'm not much of a gear head, so I don't know what all to expect. Since I'll be installing this supercharger this week, and towing a hefty trailer for 3650 miles in a 4 day timeframe, I'd like to keep an eye on it. I'm not looking for a step by step, although that would be nice, but more so just an idea of what the job entails.
Old Mar 5, 2006 | 09:41 AM
I think most of us here are using our edge to read trans temp.
Old Mar 5, 2006 | 01:03 PM
bushtree's Avatar
Yea you can do it in less than an hour. All you need to do it get yourself an Autometer electric trans temp gauge.
it will come with an 1/8" Sender. All you need to do is unscrew a bolt pluging the test port on the driver side of the transmission case and screw that sender into that same port. Then just run the wiring to your gauge.
If you need help just send me an e-mail and ill walk you though it and try to get you some pictures.
Old Mar 5, 2006 | 04:23 PM
Thanks bushtree, it sounds as if it is fairly straight forward. I didn't know if it was going to involve tapping lines or other surprises. Sounds like the hardest part for me will be to find the port. If I run into any issues, I'll drop you a line. Thanks!
Old Mar 5, 2006 | 05:45 PM
bushtree's Avatar
Yea, its pretty straight forward. No tapping or cutting required. I'll try to get a picture of the port for you.
Old Mar 5, 2006 | 06:48 PM
bushtree, does the computer read the trans temp from the same place that you are talking about?
Old Mar 5, 2006 | 09:20 PM
bushtree, that would be great! Thanks a bunch.
Old Mar 6, 2006 | 12:03 AM
gandnb's Avatar
My Coolant runs about 190, Oil Temp 180, and Trans Temp 140-145.
