Speed Volume
Speed Volume
i had the dumb speed volume on my factory stereo and when i took out the deck and installed a poineer head unit the darn thing keeps raising the volume and lowering it...I hate it. What should I do?
have you checked your new head unit? if they reconnected the speed/volume cord, and your head unit supports it, you should be able to control the levels that it works at, or even turn it off-
good luck
good luck
which wire is it...i have the plug and play harness on it...from factory harness to back of my head unit...direct plugs..i have tried to turn it off...i have even installed the factory unit and turned it off andinstalled the poineer and it still works...i hate that sh*t
It has nothing to do with the wiring.
Read the manual, and find out how to disable that feature.
It can't be that hard to figure out. If you just randomly start pushing buttons, you should get to that setting in a few minutes.
Speed pulse wire
