another edge ????
Old Feb 23, 2006 | 01:26 PM
Y2KWHT150's Avatar
another edge ????
I installed my edge last night, this morning I drove out and on about 35 MPH, I floored my pedal and felt "thunk" coming from my rearend, no noise just sense via floorboard. It was defintely from the rear housing unit...did anyone experience this? I have 04 FX4 w/ 3.73 LS.
Old Feb 23, 2006 | 01:35 PM
MoJoe's Avatar
I do not see how in any way the Edge would have done this. I have not had one single issue with mine tune wise, or anything mechanically related from installing it. I would try searching the forum for rear end clunk or drive-train clunk
Old Feb 23, 2006 | 01:59 PM
FX4_Guy's Avatar
I'm with MoJoe on this one. There is really no way the edge could cause the rear-end to make a clunk. Are you sure it wasn't your transmission shifting down a little harder than normal since you were WOT?
Have you repeated this process with the truck set to stock?
Old Feb 23, 2006 | 02:00 PM
RamSS/T's Avatar
Are you sure you did just feel the trans downshift hard (if it was from OD to 2nd thats a hard downshift)? The trucks making a few more HP so the shift down would feel a little harder...plus you were being super sensitive listening to it and playing with it since it was your first time out playing with it. Just a thought...
Old Feb 23, 2006 | 02:02 PM
Red05stx's Avatar
I would guess it could be magnifying a pre existing condition with the rear end since the shifts are harder.
Old Feb 23, 2006 | 02:05 PM
RamSS/T's Avatar
Yeah but I think most people with the rear end clunk can feel and HEAR it. No sound makes me think its the transmission.
Old Feb 23, 2006 | 02:35 PM
Y2KWHT150's Avatar
maybe I am being more sensitive with the unit. However I know this wasnt a problem before....now I think aobut it, it could be from tranny downshifting hard for that extra response needed to my WOT. I guess I wont WOT anymore. Just to side track a little from the subject, I am at level 2 and I'm not too pleased with the unit other than that digital gauges readouts. I mihgt have to try out level 3 in coming weeks, once my gas tank goes empty.
Old Feb 23, 2006 | 02:40 PM
MoJoe's Avatar
Be sure to adjust the settings from the out-o-the-box settings. You may have already done so, but if not you will see improvement. Also give a little time for your computer to learn the tune. I ran level 3 out of the box and use it for everyday driving with nothing but smiles on my face
Old Feb 23, 2006 | 02:41 PM
Kool Aid's Avatar
If you're not pleased at level 2, you might as well sell it.
If level 2 did not make a huge difference in your truck, you either don't recognize the difference, or you have something connected wrong.
The difference in stock and level 2 is night and day. Level 3 is only better at high rpm's and may even be a little less "feeling" than level 2.
Old Feb 23, 2006 | 03:34 PM
ThumperMX113's Avatar
I think your experiencing a hard downshift or your u-joint clunking.
Old Feb 23, 2006 | 04:12 PM
asinatra's Avatar
You are more than likely experiencing the tranny slipping into neutral before completing the "4-3-2" kick down shift.
Old Feb 23, 2006 | 04:23 PM
Y2KWHT150's Avatar
I'll give few more days.....Kool aid....sure wasnt night and day difference. Everything is hooked up right...cause it knew my hex code and I have 4 parameters showing...
Old Feb 23, 2006 | 04:25 PM
I think you thought the tuner was going to make your truck feel like its supercharged. .
Old Feb 23, 2006 | 04:27 PM
MoJoe's Avatar
Did you adjust the unit yet? Or are you running the generic tune?
Old Feb 23, 2006 | 04:36 PM
Y2KWHT150's Avatar
As soon as I got it, I updated both firm and calib to the latest. I think they were version 13 and 15a. Then I ran level 2 without any adjustment. I must tell you that as soon as I put my foot on the pedal it response which wasnt there before, but other than that not much to talk about yet.
