Badge and Ford oval removal, how to ?
Old Oct 14, 2006 | 08:14 PM
whitecrystal1's Avatar
Originally Posted by welfare wagon
I used a plastic drywall spreader 2 inch wide from Lowes less then a buck, taped off around the emblems, but in your case its not needed and just pushed the spreader under the emblem and once I got 1/3 thru it I could pull the emblem off by hand, this also applies for the F-150 badge too.
I think its highway robbery that they are charging to remove the emblems before painting, I worked in a bodyshop for 2 years and that was part of the prep job before painting just as is sanding, taping etc, I woud get a second opinion even if you take them off yourself, it makes me doubt the quality you would recieve.
They may have just been trying to help save him some money and do the job cheaper. I was quoted $250 for mine. I didn't ask about me pulling the emblems off to be any cheaper. I can understand the shop charging to remove them it is one more thing they have to do to get it done.
Old Oct 14, 2006 | 08:58 PM
tworangerted's Avatar
I know there are aligment holes behind those.On my 05,the painted part of the F-150 emblem is flaking off.I pulled the emblem off the drivers side to replace it with one just like on the tailgate(just says F-150 instead of F-150 5.4 Triton)Just heat it up good and pry,then use WD-40 to remove the goo.
Old Oct 14, 2006 | 09:17 PM
Here I foung this picture from another thread. It shows the aligment holes on the ovel emblem.
Old Oct 18, 2006 | 04:09 PM
Alfdog's Avatar
Originally Posted by Alfdog
I have tried WD-40, goo gone, alcohol, hair dryer..... is there anything else that I can use to get that damn residue off the paint?
