So what's the verdict on the 2" or 2.5" Autospring
Old Feb 19, 2006 | 05:47 PM
mj8's Avatar
mj8
Originally Posted by badkarma38
bought them off ebay for $100 shipped. took me about 3 hours to do the install and thats with alot of distractions. also i used all hand tools and didn't have any problems.
how do you pop the ball joint off without damaging anything?
Old Feb 19, 2006 | 06:47 PM
badkarma38's Avatar
you take the nut off first--i think 19mm-- then hit the top of the spindle around the ball joint carefully with a hammer. i wrapped the ball joint in a rag, then used a 15lb sledge
also, i worked the a-arm up and down a few times with a floor jack.
Old Feb 19, 2006 | 07:01 PM
KSpencer's Avatar
my truck looks level to the eye, however, the back sits 3/4" higher which is what i wanted so that it doen't sag when hauling. i'll post some pics also after i get it cleaned and aligned. i'm very satisfied with it
If you haul anything over 500 lbs, it will sag. The leafs on these trucks are pretty soft, so it does not take much. I had installed the 2 inch "old" design the first time and saw that the UCA-coil contact was getting worse. After a good discussion with Kevin at Autospring, I swapped it out with the new design. So far no problems and I have about 1/4 inch of clearance now fully off-loaded on the front, so my spindle is plenty long. I do know that the varying lengths of spindles are the cause of UCA-coil issues with these spacers. Some have this problem with the 2 and 2.5 inch spacers and some don't depending on this length.
Old Feb 19, 2006 | 10:13 PM
mj8's Avatar
mj8
How do you know if you are going to have a problem before you actually install the kit or is that not possible?
