4.56 gears
Old Feb 19, 2006 | 03:45 AM
bluehosefb90's Avatar
4.56 gears
I have the regular 3.73 gears in my 04. I want to upgrade to get better acceleration(or get my stock accel back rather). What have guys been cutting their 0-60 and 1/4 mile times with similar tire setups that i have? What i really want to know is it worth it to change the gears or not.
Old Feb 19, 2006 | 05:01 AM
fourpointsix's Avatar
Yes it is very worth it! My truck had 3.55 gears stock and after changing to 20s and 32 inch tires it bogged quite a bit. With 22s you definitely will benefit because that's a lot of extra weight to get rolling! I am running 4.56s and now that it's tuned properly (Bamachips ) she runs like a raped ape! Gears are something that everyone overlooks because they are pricey ($500 4x2 and $1200 4x4 installed) but well worth it for restoring your power and gas mileage. With the 20s and 3.55 gears I was getting 13 in town and now I am up to 15.5-16 in town.
Old Feb 19, 2006 | 05:39 AM
do you have any before and after timesheets?
Old Feb 19, 2006 | 06:02 AM
Screw2004's Avatar
your gona need traction bars for sure since you slamed your truck
Old Feb 19, 2006 | 06:16 AM
since thats something i have no idea about.....i know what traction bars are, but why would i need them since i slammed my truck, rather than a stock truck? I know many need them on taller tired trucks. other than that im clueless.
Old Feb 19, 2006 | 06:29 AM
Screw2004's Avatar
Your gona have some real big TQ gains. Since you dont have stock rear leafspring's. And your gonna get some wicked wheel hop.
, and your pinion angel will be off real fast then you will jack up your drive shaft, maybe even bust your leaf spring's.
How do I know this Because I have done what you plan on doing and that's some off the crap that will happen unless you get those Traction bar's
Old Feb 19, 2006 | 08:00 AM
even if im not running that much horsepower? I realize that for the higher hp trucks like the lightning that are running around 400 rwhp need traction bars for wheel hop and what not, but i dont plan to run at the track, just every now and then so i know what i have under the hood and to mess with my buddies at work. I dont want to fubar anything in my suspension like the leafs or the driveshaft though. I want to find out all the info before i do anything....i do appreciate your help though, i just checked the lightning forum and i now know 100 percent more than i did this morning. Thanks
ps....are you saying this because you have messed up your driveshaft and leaf springs with the 4.56's? I believe you have the black truck with the black 20's on it. Just wondering
Old Feb 19, 2006 | 05:57 PM
Screw2004's Avatar
Yes that's me it use to be slamed lowest was 4 1/2 front 6 1/2 back
Old Feb 20, 2006 | 05:31 AM
would the fact that you had air bags have made any difference? (not saying you do, but i would assume since the 4/6 drop). Has anybody else with the 4.56's had any problems thus far, cuz i know that you all have floored it to see what the response is like.
Old Feb 20, 2006 | 08:20 AM
ThumperMX113's Avatar
If your going to do the 4.56s, you really need to get the traction bars. While your at it get a rear sway-bar, you'll thank me later.
