electronic climate control
Old Feb 17, 2006 | 04:45 PM
5point4's Avatar
Originally Posted by Thrill Racing
WOW. You guys rock and I already have the auto climate. I would have never thought it would be this easy to do. Obviously, easy being a subjective term.
It's very impressive what us Ford guys will do to have exactly what we want.
Old Oct 3, 2007 | 11:36 AM
kingdog's Avatar
Originally Posted by 928gt
>I am not saying you are wrong, just a little confused still.
No confusion here.
>To me it looks like we dont need pin #3 in the instrument cluster anymore, since page 60-3 says its for the manual system,
>I dont see any pin input for an auto system.
Correct, that is what I said you move Pin #3.
>What I am seeing is that we just need to run a wire from pin 12 of the EATC to pin 3 of the data link connector,
>which is where UBP is....once again, not saying you are wrong, just a little confused.
Still no confusion, with my way I use an existing factory wire and move it 6" from one Instrument cluster connector to another WITHOUT having to run a new wire. Ironically it is the same exact color (VT) and wire as original on the Manual and Auto systems. I much prefer to use as many of the orignal wires as possible and not run any additional wires. With my layout the only additional wires I have to run are 3 for the Drivers Side heated seat controls (I am using the 3 leftover from the Fan Resistor Pack to get the wires for the passenger seat heater controls down to the passenger feet area), and if I look a little farther I may find a way to do that without any new "non original" wiring, as a matter of fact I can probably use the wires for the reverse sensor switch harness and at least get me down the parking brake pedal area without adding any extra non original wiring at all in the dashboard area.
Hello,
Are you able to receive emails? I just sent you one and wondering if you can receive..
Old Nov 20, 2007 | 04:35 AM
StickyF250's Avatar
Did you guys have any luck with this?? I am looking into this and was wondering what else i will need besides the EATC?
I kinda understand the directions above, but not 100%... Can anyone explain a little different?
Old Nov 20, 2007 | 07:36 AM
ONE04FX4's Avatar
Talking
i to am wanting to do this.
Old Dec 12, 2007 | 12:14 AM
wadespencer99's Avatar
You guys rock. I just replaced my 02 FX4 with an 04 FX4, and I want to do this mod, along with factory heated seats.
Any chance you could post a list of the exact parts needed, whether they are easy to find in a junkyard or should be bought new, and part numbers if you have them?
Thanks so much!!
EDIT: Looks like I came across most of what I was looking for here:
https://www.f150online.com/forums/sh...d.php?t=233927
Old Dec 12, 2007 | 04:52 AM
Josiah's Avatar
Does anyone have the wiring diagram for the electronic climate control? I'm looking to see whether it's a ground or 12v pulse that engages the defrost mode. Second, I'm looking for what color wire the defrost mode is. I'm going to wire my remote start to engage this for those cold mornings. I currently have it hooked up to my mirror defrost.
Old Jul 9, 2008 | 05:21 PM
teknics's Avatar
I love resurrecting old threads!
I just snagged an auto climate control on ebay for a great price. I only bid on it thinking - I wont ever win at this price, and I did.
So - it's time to dig through the archives and see what I need to do as far as pin swaps and wiring. Are the diagrams still floating around?
TIA!
Old Jun 23, 2011 | 08:07 PM
-07f150-'s Avatar
Did the swap now myac don't work any suggestions??
Old Jun 23, 2011 | 11:33 PM
City of Champs's Avatar
did you follow the wiring instructions on the first page?
At the Instrument Cluster you move pin# 2 (AC Demand) from the smaller connector (C220B) to Pin#29 (UBP Bus) of the larger connector (C220A)..
Then at the HVAC Controller you move Pin# 3 (AC Demand) of the larger connector (C249A) to Pin#12 (UBP bus) on the new smaller connector (C228B) of the EATC
The color of the wire is VT (violet).
Old Apr 30, 2013 | 01:31 AM
memphis70047's Avatar
Did you guys ever get this mod to work? I am wondering cause I have an F150 XLT that I have already upgraded to FX4 gauges and I want to do this mod.
Old May 1, 2013 | 09:55 AM
I have been running the swap for almost 5 years now.
Old May 6, 2013 | 03:54 AM
Cool, I understand the pin changes needed on the wiring harness but what else do I need to do to get this to work?
