FYI: MY2006+ Relfashing
Originally Posted by erick_e
Just curious, are there any TSB pertaining to 06 trucks? My 06 has none of the throttle lag issues that my 04 did. But 1 out of every 20 starts, it just cranks then dies.
2006 F-150 - US (English)
06-2-5
POWER FOLDING MIRROR OPERATION
05-26-24
VIBRATION DIAGNOSIS - TIRE/WHEEL RUNOUT
05-26-7
RAPID SHOULDER (TOE) WEAR ON INSIDE EDGE OF FRONT TIRES
05-25-5
5.4L 3V WITH P030X AND/OR P0316 ACCOMPANIED BY SPARK KNOCK
05-25-2
NEUTRAL TOW CAPABILITY - SERVICE KIT REQUIREMENTS
05-24-3
NOISE FROM BACK GLASS - POWER SLIDING REAR WINDOW ONLY
05-22-8
WDS COP KIT DIAGNOSTIC TIPS - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING
05-21-18
SERVICE PROCEDURE FOR REPAIR OR REPLACEMENT OF COLUMN SHIFT CABLE
05-18-7
WIRING - SOLDERING AND CRIMPING REPAIRS - SERVICE TIPS
05-16-12
SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS
05-16-11
SAFETY BELT RETRACTION SPEED
05-9-23
STEERING COLUMN RATTLE/CLUNKING WHILE DRIVING OVER ROUGH SURFACES AND WHEN TURNING THE STEERING WHEEL
05-9-18
DISCHARGED BATTERY - CHARGING SERVICE TIPS
05-9-3
INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
________________
TSBs found:14
I sometimes get some vib issue's. Once a week. No idea why?
I just can't pin point a vib/shuddering from a start. Only during first gear change.
I called Ford and because it only happen's a couple of times a week they won't be able to pin point it. I guess they want to replace a tranny or torque converter.
Vibration issues, HA!!!!
My truck has been in 2x's already (3000 miles and 2 months after I got it), with a 3rd time coming up. I've taken it to 2 different Ford dealers, and neither one of them have been able to get rid of the wheel vibration. Road Force balancing, isn't doing much to address that issue either. I guess I will be calling Ford Customer Service today, because the next time I take it in I'm sure that I will have the ability to file some sort of formal complaint.
Other than that I love that truck, and I hate to be without it, especially after driving an Escape for a loaner.
So far I haven't noticed any vibe problems with mine. It is much smoother than my '03 FX4 was for ride and engine vibration.
My '03 had a terrible rough idle the whole time I had it from new, I could be sitting at a red light and look over at the passenger seat belt just bouncing up and down on the seat.
The only thing I have noticed with my '06 is that the brake pedal drops down a whole lot further than I would like it to. Anyone else notice that?
I can honestly say my 06' is doing good...if I hit a hard bump I sometimes hear a loud bop in the back (I think it might be that power rear sliding window?) no vibration issues at all...smoothest vehicle I have ever owned...I've had it up to about 105 mph and it was like floating on glass...I cruise on the freeway at 70-80 all the time and no issues...very happy with the truck so far...
I do notice the big time lag when you push hard on the gas...it takes like a full second before it drops down a gear and gets going...I think that's the fly by wire throttle crap...everyday driving acceleration is awesome though...just when you step on the gas hard...I've even brake-torqued it a couple times and it does a pretty good job
my friend told me it only did a one wheel burnout even though this is a limited slip rear??? I love my power moonroof! that thing is flawless...
