edge lightning software?
downloaded the software and connected the usb....not reading anything. reread the directions and i failed to install the drivers. hit the install drivers and still nothing. i ended up going into add/delete programs and got rid of the whole program. went back to the site and reinstalled the program (note:that only took about a second? dialup).....hit the install drivers and it still says the edge isn't hooked up now? i am by no means a big computer guy, what should i do? thanks guys.
Do not connect the Evolution to the PC until you have installed the Lightning software and then gone to the Edge Products\USB Drivers folder and installed the appropriate drivers for your operating system. If you are using WinXP or Win2k you will get a warning dialog stating the drivers are not digitally signed. Click on Continue and intsall them anyway. Hope this helps.
Good luck!
ok, i have reinstalled the software....went to folders to see what drivers i had and it only showed 11. the bottom of the page showed i have 10 hidden....how do i uncover what i need before i plug in the edge? thanks...
"my computer". "c" "edge" "usb drivers" thanks guys!
ps. i am supposed to have 21 showing by the way....
Originally Posted by scorpio333
Out of curiosity is the Edge software Windows only or is OS X supported as well? I'd bet dollars to donuts it won't run on a Mac.
I can try it tomorrow at work, i have a spare MAC for testing for just such an emergency....
ok guys, i now have all files showing....i have already gone thru the start button and programs to get to the edge program to preinstall drivers....now what do i do before hooking up? is there someplace i can look (a folder or something) to see if it is ready to read the edge now? thanks.
Originally Posted by gobra
If you own a MAC, you ought to be used to it by now and have a backup PC in the closet somewhere........
Originally Posted by afdt2
I'm still running Windows 98 SE
edgeunin.exe edgeunin.u2k edgeunin.u98 edgeunin2k.exe edgeuninme.exe
edgew2k.inf edgewdm.inf PreInstaller.exe setup.ini slabbus.sys
slabcm95.sys slabcmnt.sys slabcomm.vxd slabcr.sys slabser.sys
slabvcd.vxd slabvcr.vxd slabvxd.inf slabwh95.sys slabwhnt.sys
am i missing something here? when i try to open the vxd files it asks me what program i want to open it with.....? help!!! LOL
vxd files are virtual device drivers--these are software files that act as buffers between hardware devices and the software program. In other words, you won't be able to do anything with the vxd files by themselves.
If you've installed your USB drivers correctly, then connect your Edge unit to your computer. Then navigate to the "C:\Edge Products\Evolution Lightning" folder and double-click the "Lightning.exe" file. (Alternatively, you can access the Lightning software program by using Start|Programs|Edge Products|Evolution Lightning). After you start the Lightning software, look in the lower left-hand corner of the program window. If your USB drivers are correctly installed, you should see "Connected." If the USB drivers are not installed properly, you will see "Disconnected."
I ran setup.exe and everything appeared to install correctly
and I then installed the drivers and all appeared to go well.
I can read the Edge for update info. BUT everything says I ain't connected and they appear under control panel/system.
Don't know...btw, this is for windows 98 se.
