Pics of clearance lights installed.............
Old Jan 28, 2006 | 11:23 AM
  #31
Frmboybuck's Avatar
How big of a hole do you need to drill for each light? Any fear of leaking water?
Old Jan 28, 2006 | 08:58 PM
  #32
WaWaTuSi's Avatar
Originally Posted by asinatra
While you guys are at it why not put some on the hood, or maybe ontop of the side mirrors? Or even get some stacks for your exhaust and the reflective tape going around the base of the truck with the reflectors too? And then you could all quit your day jobs and be wanna be "f150 truckers"
Looked for the pics of your "look-Good & Go fast mods".... yet no linky....
Seems you bought a pick-up to "go fast".... Some might consider that more silly than clearance lights on a pick-up truck similar to what is available on the super-duty's....
I for one like em and want to do the mod. Personally I am not a fan of making a 2wd pickup "fast" Thats what Mustangs are for, But hey thats just me...
btw... I'd love to see a pic of your "truck"
"MY04 F-150 4X2 SS R/C XLT 4.6L 2v
Born on Date: 02-14-2004 (USA)
Some look-good & go-fast modifications ..."
Old Jan 28, 2006 | 09:01 PM
  #33
WaWaTuSi's Avatar
Originally Posted by RamSS/T
That really makes no sense...how are they supposed to help you judge distance when height is an issue? You can't see them from inside the cab. They arent bright enough to illuminate anything infront of you at cab level...at least not until its too late. Maybe if you have them on and you try to go through a drive through thats too low you will know its too low when you knock them off???
I think the law about them having to be on trucks towing wide loads makes more sense as to why big trucks have them. Not that the law makes sense, but the fact that the law exists explains why they put them on dulleys from the factory.
AS you SLOWLY aproach a clearence the lights right before you hit the overhang will cast a dim but definate shine on it indicating you better get out and look.....
Your Antenna on your f-150 kinda does the same thing I found out... lol
Old Jan 28, 2006 | 10:20 PM
  #34
SSpiro's Avatar
Clean install, but I'm with Asinatra.. kinda silly on the 150's..
Old Jan 28, 2006 | 10:41 PM
  #35
The professor's Avatar
I like the look of them but I'm not willing to do the work to install them. And By the way Mwheue, your truck looks like something batman would drive .
Old Feb 27, 2006 | 09:11 PM
  #36
shadled's Avatar
Dumb question...
Do the 2004 f150's have a single or dual sheet metal roof? (What I am getting after is, when these lights get installed do you drill through both sections or is there a gap between the first and second roof (Like my 1977 Dodge).
Dumb question, flame away.
Shadled
Old Feb 27, 2006 | 10:46 PM
  #37
mwheue's Avatar
Single layer...
Old Jun 19, 2006 | 10:19 PM
  #38
sean_somer's Avatar
mwheue, where did you get your clearance lights?
Old Jun 19, 2006 | 11:00 PM
  #39
patshea098's Avatar
im going to do this once my truck is lifted
looks great
Old Jun 20, 2006 | 08:00 AM
  #40
nuclearthreat54's Avatar
I was gonna do that but I relized that I am still in school
Old Jun 20, 2006 | 08:13 AM
  #41
ThumperMX113's Avatar
Oh god. .
Old Jun 20, 2006 | 08:28 AM
  #42
04 RED LARIAT's Avatar
I took the easy way out and went with the sunvisor with lights already on it.
Old Jun 20, 2006 | 08:35 PM
  #43
sldghmr's Avatar
To me, they give you a MUCH better idea of the size of vehicle that is coming towards you. Also, if I were on a narrow road I'd watch for a big azz box or trailer behind said vehicle. The above pic shows what I mean....
Old Jun 21, 2006 | 01:54 AM
  #44
Corey05Lariat's Avatar
Its little Superduty Jr.
Old Feb 25, 2007 | 10:35 PM
  #45
roadawg's Avatar
Originally Posted by roboots21
"Roof Clearance Lights", the purpose is stated in the name. They are there to give off light on taller trucks to make sure that if height is an issue that you will not have to worry about clearance above your truck. The lights are supposed to help you judge this.
Plus I think on alot of trucks they looks cool, and that is purpose enough alone!
Aaaah, not exactly correct, the cab marker lights in the 1-3-1 configuration are to let oncoming traffic know there is a 80-102 inch wide vehicle (truck) approaching. I don't believe it has nothing to do with "height" you can't see them from inside while driving. That is unless you are following a Beneto Fuel Tanker and you could probably shave/pick food outta yer teeth in the reflection from the back of their tankers. The old configuration (and I DO mean old) was a marker light on the front top corner of the cab. Later the regs changed to have the 5 across, one on each corner, three in the middle. At least that was how it was explained to me years ago when I drove truck for a living. That said, I ended up with a set of markers on my 1990 F150 after a kid dented the roof and the dents were correctly spaced and covered by the Ford lights of that era. Not only did it look good, it vastly improved visability to oncoming traffic especially in a snow storm. I got a lot of complements on them as well as I had to explain it wasn't a F250-350 frequently. Regards, Bob.
