question about my 3.55 LS
Old Jan 6, 2006 | 11:04 AM
04F150PA's Avatar
I am not sure if its working correct? i parked 1 tire in snow and the other on dry pavement and i would not move.. i had to back up and go.. is this right??
Old Jan 6, 2006 | 12:52 PM
sspangl's Avatar
i have the same but i have never tried any "experiments" like that. However, i have ( and many off-roaders ) will put the e-brake on just a little to provide some resistance in slippery situations at take-off and it should work fine then. I would do this with your experiment and see how it works.
Old Jan 6, 2006 | 07:27 PM
jljue's Avatar
I have done that little trick with my Mountaineer since it was 2wd, and it seems to help a little bit. Limited slip isn't as good as a locker offroad, but it's more street friendly when making turns, especially a quick turn on a wet road.
Old Jan 6, 2006 | 07:34 PM
hmfic's Avatar
How much did you let the wheels spin. Both tires should spin once the spinning tire turns approx 3 times. They do this so when your making a turn on dry paved surfaces it doesn't lock up or bite due to turning.
Old Jan 6, 2006 | 08:01 PM
GrizfromKY's Avatar
Edu-mu-cate me. Is LS like posi=trac at all?
Old Jan 6, 2006 | 08:05 PM
Matt 05'FX4's Avatar
Posi and LS are the same, just different names for each. Both use limited slipping clutches. I had one tire on ice and one on pavement one time and I hit it kinda hard and the one free wheel just spun up like I had an open dif. I guess these clutches aren't as tight as they should be.
Old Jan 6, 2006 | 08:22 PM
GrizfromKY's Avatar
Thanks Matt. So my 2wd is truly a 2wd, not a 1wd?
