Got a hole in my radiator !
Old Dec 27, 2005 | 11:07 PM
bigyellowtruck1's Avatar
well this morning my troyer e-fans arrived at my local performance shop, true performance of sarasota, anywas, the install was going fine until the mecanic some how snagged the radiator and caused a hole in the radiator ! this in part caused it to leak and is pretty much useless now !
well just wanted to let u know my pain and also ask how much for an oem replacement and how much for a high performance one ? i have been looking at ford racing but they only have the high performance one's which are $700 ! soo can someone tell me what the damage is so i can look into the shop buying me a new one ?
Old Dec 28, 2005 | 01:23 AM
cavermatt's Avatar
shouldnt the guy that made the hole have to fix the problem????
I think you can patch it if it is a small hole.... buy hey you can always sell the radiator to a scrap yard for $.50 a pound, so you could make a few bucks to put twards a new one.
Old Dec 28, 2005 | 01:29 AM
asinatra's Avatar
Try an egg.
Old Dec 28, 2005 | 07:38 AM
Marc Carpenter's Avatar
The shop should pay for the mechanics goof. He must be a real gem of a mechanic as the installation rods are very easy to install....
Old Dec 28, 2005 | 08:18 AM
PenguinFX4's Avatar
See if Be Cool makes a radiator for our trucks. They always make the absolute best radiators out there and they are usually "drop-in" installs with no modifications required.
www.becool.com
If they don't have anything, then I'd go with Ford Racing.
Old Dec 28, 2005 | 09:45 AM
04NickySP2's Avatar
fordparts.com shows them listed for 148.41 standard duty and 149.11 for the heavy duty.
Old Dec 28, 2005 | 09:58 AM
kd4crs's Avatar
I never have liked the idea of poking something through the radiator to mount anything. Now I like it even less. Problems such as this are why I will be going with the Flexalite 270 efans. They bolt right on.
Old Dec 28, 2005 | 12:57 PM
bigtruck311's Avatar
same thing happened to me but it took 2 years for those stupid rods to wear threw, dont use the rods supplied with the troyer kit, i am using some perma cool nylon ties part # 105 to hold mine in that i got from madenterprise, it is very hard to braze the hole in a aluminum radiator, and even harder to heliarc it, so you will most likely have to get a new radiator, sorry to hear about your problem, you should call troyer and let him know about the rods so maybe he will change the way it is atached in his kit i have already called him and let him know about the nylon kit from perma cool, good luck
Old Dec 28, 2005 | 01:17 PM
What good would it do to call Troyers???
I am not real fond of the rods either, but they came with the kit and I used them as most have.Yes, there is a better way to hold the fans in place, and I am sure it is being worked on as I type this, but of all the fan kits Troyer has sold, I wonder how many have actually caused a radiator issue, verses how many have not?
But you are missing the point here...No matter if the fans attatched with a strap, a bolt, or a wigget, the installing mechanic is the one who was installing the fans, and he should accept responsibility and pay for the repairs that ""HE"" caused...
Old Dec 28, 2005 | 02:08 PM
it would be good to call troyer to let him know that maybe the way he has his kit setup may cause problems and there might be a better way to do it, if there was a better way do do something that you are selling wouldnt you want to know about it? and this is the third problem i have heard about just in a 7 day time period having to do with the way his fans are mounted, if no one lets him know how can he fix/ emprove his kit? and yes i agree with you that the mechanic that caused the problem is responsible for the damage but if the kit used a diffrent method than the problem would have never acured, that is just the way i see things, i would want to know if something i am selling is causing problems so i could fix the problem for people down the road, just my 2 cents
