firewall
Old Dec 21, 2005 | 12:07 AM
wedgewood 4 x 4's Avatar
Question firewall
does anybody know where there is an opening thru the fire wall, i am trying to feed a wire for my fog lights.
thanks :santa:
Old Dec 21, 2005 | 12:14 AM
IzInBloOm's Avatar
On the passenger side behind the glovebox there is a huge grommet with eletrical coming through. You can get at least another wire or two through it. Drop the glove box and reach deep. I found it was easier to pop it out, feed my wire then put it back in. It's a lot of work, but it's the right way to do it.
-ii
Old Dec 21, 2005 | 12:50 AM
nvrenuff's Avatar
There is also a grommet on the drivers side above the steering column which is accessible from both sides. Can't miss it, there are a couple wires through there already. This is the hole I fished the cable for my cell phone booster antenna through, quite easily I might add.
Old Dec 21, 2005 | 01:09 AM
countyboy04's Avatar
There is another hole near the gas pedal. Pull back the carpet and you should see it.
Old Dec 21, 2005 | 07:50 AM
thanks for all the help.
Old Dec 21, 2005 | 09:12 AM
04NickySP2's Avatar
Norton makes a good firewall
Old Dec 21, 2005 | 01:43 PM
smokestoneF150's Avatar
Old Dec 21, 2005 | 02:06 PM
ChrisAdams's Avatar
Not really that good. For a free one that works good use ZoneAlarm.
Sorry, I had the same thought when I saw the post. .
I prefer to use the one below the Master C. it is big, easy to reach and if you pass the wire through it (make a hole with an icepick) it protects the wire well.
Chris
Old Dec 21, 2005 | 02:13 PM
04NickySP2's Avatar
Chris
Someone always has to be a damn critic.
I have cacti monitoring my laptops port on our cisco 6509 switch. The traffic coming from my pc sometimes amazes even me.
Old Dec 22, 2005 | 12:21 AM
love the jokes , but serious thanks for the help
:santa:
