Aftermarket projector headlights and HIDs
Originally Posted by JS04CREW
How is the light output of the projector using the H3 bulb when projector is used as low beam. Is it comparable to low beam on factory H13?
Those lights look sweet!! I love mine and it sort of btings the front end all together.........btw check the classifieds for 04-06 for those H13 bulbs!!
Looks great! Love the bull bar
Originally Posted by titans615
I actually bought a pair of the twin halo projects, yes, yes and they have a bulge but the dont look bad at all, the Halos look sweet at night. I still need to do a bit of Adjusting though
I've got the xtravisisons x2's in there now. Is that the ones you are referring too?
Projector beam
How is the projector beam pattern? Is the light output good?
poor girl, i was goin up grade to an 06 front but now looks like might be the best time i have to do it anyway Last edited by titans615; Jan 16, 2006 at 11:16 AM. Reason: adding
Originally Posted by Josiah
So yankee, how much better than stock is this setup, was it hard to install and how much did it cost. Looks great.
yankeesfan81..
Where did you install the ballast? I am looking at doing the same setup and wanted to know where you were able to mount the ballast and do you have any pictures of the location?
The cut offs dont look that bad since they are halogen projectors.
Originally Posted by yankeesfan81
here is the cut off of mine with my HIDS
They look better than the pic shows..
Yes
Originally Posted by cvc14
Do you have a picture of the headlights installed on your truck..
yankeesfan81..
yankeesfan81..
Yes i have pics and i will put them on soon
yankeesfan81..
Titans. On my projector setup I dont think there is any adjusters for the projectors or the headlight assembly itself..
Titans. On my projector setup I dont think there is any adjusters for the projectors or the headlight assembly itself..[/QUOTE]
Were yours pre adjusted basically just plug and play? mine were not straight as in one beam was higher than the other so i had to adjust the whole bracket that the headlight attches to. Yankee do you have a pic of what the light pattern looks like from the cab?
