Roush hood scoop
i personally love the roush scoops. i personally never really liked the smooth lines on ram air hoods, and the roush scoop looks much better than the stick on POS's
also, just look at the previous mustang gt's, bolt on non functional scoop
i had to take mine off for a while and i cant wait to get it back on!
BTW, for you guys with the stock "shaking hoods", here is a TSB concerning this, hope it helps........
TSB 04-18-8
09/20/04
HOOD FLUTTER AT HIGHWAY SPEEDS
FORD:
2004 F-150
ISSUE
Some 2004 F-150 vehicles may exhibit hood movement at the back of the hood due to high air turbulence, while driving at highway speeds. This condition may be amplified by the installation of an accessory bug shield and may be more pronounced when passing an on-coming vehicle on a two lane road.
ACTION
Refer to the following Service Procedure.
SERVICE PROCEDURE
1. Confirm that the hood is flush with the front fenders at each front corner. If the hood is under-flush adjust the hood stops to raise the hood flush with the tops of the front fenders.
2. Check the amount of drag at the rear hood to cowl seal with a piece of paper. Place a piece of paper between the seal and hood, close the hood and then slowly pull the paper out.
a. If there is sufficient drag, indicating good seal to hood contact, return the vehicle to the customer.
b. If there is little to no drag, obtain locally a piece of fuel hose 147 cm long & 11 mm diameter (58" long & 3/16" diameter). Lube the hose with a soap-based solution and install the hose inside the hood seal bulb.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
041808A Check And
Adjust Hood,
Includes Time
To Adjust Hood
Bumper Stops,
Check Hood
Rear Seal
And Install
Hose Inside
Hood Seal Bulb
DEALER CODING
CONDITION
BASIC PART NO. CODE
TSB 04-18-8
09/20/04
FORD:
2004 F-150
ISSUE
ACTION
SERVICE PROCEDURE
WARRANTY STATUS:
041808A Check And
Adjust Hood,
Includes Time
To Adjust Hood
Bumper Stops,
Check Hood
Rear Seal
And Install
Hose Inside
Hood Seal Bulb
DEALER CODING
CONDITION
BASIC PART NO. CODE
