center console subs
Old Nov 27, 2005 | 04:52 PM
etrevino103186's Avatar
center console subs
Has anyone successfully taken the 20% out and put a sub box in? I have the floor 4x4 shifter so I am tryin to figure out what the best thing to do is. I would ideally like to a fit a 12 or 2. If you do have the setup can you post pictures?
Old Nov 27, 2005 | 05:24 PM
Tical84's Avatar
I've been contemplating doing that or using the space behind my reg cab. I've started drafting a couple plans already and will let you know what I come up with.
Old Nov 27, 2005 | 06:07 PM
Josiah's Avatar
Not a bad idea, let us know what you do in fact come up with.
Old Nov 27, 2005 | 06:41 PM
rustinh1's Avatar
i thought about taking the flow through console from a lariat and putting it in my xlt screw. then, i could make a box that uses the space from the dash to the console as well as the open space under the cupholer area. the cutout for the center console shifter could be used for ports for a custom bandpass box. i don't know for sure if it would work, but I thought I would think out loud.....
Old Nov 27, 2005 | 06:49 PM
jokergomez81's Avatar
right now im doing 3 amps in the 20% center section, work stll in progress.
Old Nov 27, 2005 | 07:56 PM
SoundPer4mance's Avatar
wow nobody remembers me!! haha, check my gallery, under mods
Old Nov 27, 2005 | 08:10 PM
I could never find your pictures BOB! Now I can!! I think I might do the tweeters mod. I have never had tweeters. How do I wire them up. The sub bo wouldn't work for me since I have the on the floor 4x4 shifter.
Old Nov 27, 2005 | 08:44 PM
i didnt even know they offered the floor tcase shifter, thats pretty cool!! i have my tweeters wired into the front channel of my head unit, and the door speakers on a seperate amp
Old Nov 27, 2005 | 09:01 PM
that sounds pretty good but the deal is when and if (and I will) I put power windows where I have the manual cranks I want to put tweeters there....so you think two sets of tweeters will do any good? The ones on the dash seem more practical set right in front of your face but I dunno what to put on the holes?
Old Nov 27, 2005 | 10:02 PM
technically the best place for them would be on the door, by the mirror. ill probably add another set there
Old Nov 27, 2005 | 10:05 PM
I agree now what will I do with those 4 holes!?
Old Nov 27, 2005 | 10:08 PM
duct tape i dont know, i think those goofy covers are the only way to go unless you get new door skins
Old Nov 27, 2005 | 10:11 PM
nooooo! I think I might have to make a post, check that it has already been done. I might have to ask Myst. The caps are so damn ugly and I barely have enough money for the motors much less new skins.
Old Nov 28, 2005 | 10:37 AM
Does anyone know if the 20% is hollow underneath. I thought about putting the sub in the middle but the gf likes to sit next to me..Soooo I was wonderin if I could stick a 10 or 12 in there and then put it back down...? Does that seem possible? If anyone has done it how does it hit and please post some pics.
Old Nov 28, 2005 | 12:44 PM
ChrisAdams's Avatar
It's hollow, but you won't be putting a sub in there. It's quite small, and the airbag control module is in there. Don't put strong magnets next to that. You wouldn't like that.
Pull up sharply on the bottom of the center seat at the front. Yank it up and take a look. Nothing to it.
Chris
