To anyone wanting the Rancho 9000 series adjustables
Old Nov 27, 2005 | 09:02 AM
MoJoe's Avatar
RS9000 series front adjustable 0-2.5" and rear shocks
P/N
front: RS99768
rear: RS99286
Incase anyone here wants a good deal imo from Summit Racing. I just paid $570 total from Summit last night (plus you get a free in cab controller setup with the purchase of 4 shocks which saves you $150). That includes the back shocks also. I bought them to run 1.5 inches in the front. The front will not ship until the 5th of December, but I can wait...
NOTE: I had to contact them about the compressor/incab setup. For some reason it was not tagged to the front 9000 adjustables I bought, but over the phone they fixed that. Just incase anyone orders.
Old Nov 27, 2005 | 10:06 AM
Death 2004's Avatar
I just went through summit but the gave me a part number for the front and it was 99767 in stead of 99768. Is the 99767 non adjustavle one?
Old Nov 27, 2005 | 10:08 AM
MoJoe's Avatar
I believe so. There is a big price difference. I know the other threads I have read in this forum have pointed to the 68 for the adjustable one. I think the 67 is fixed mounted with the spring cup.
Old Nov 27, 2005 | 10:28 AM
Death 2004's Avatar
Thanks, I just changed my order. I went on the rancho sit and it said the same thing.
Old Nov 27, 2005 | 06:40 PM
KiCk aSs FX4's Avatar
where are you planning to put the incab adjustable thing?
Old Nov 27, 2005 | 08:48 PM
MoJoe's Avatar
Depending on the size of it, I was going to make brackets and put it in the blank space under my cup holders. I ordered my truck without the console. I hope it will fit, if not I will have to wait and see.
Old Nov 27, 2005 | 09:50 PM
MoJoe's Avatar
Thanks for the pic Now I should have no problem with putting it there.
Old Nov 28, 2005 | 03:23 PM
tx-import's Avatar
I was trying to see if you could disassemble the unit and then order teh ash tray assembly from Moss motors where it will hold 3 guages, I belive 2 1/16". It is in the factory carbon fiber trim form. I figured put the guages in there and the button just above it in where the sig. lighter is. I have the flow through console. In the third spot you could pur an oil tem guage, trans temp. guage or clock. Just a thought. this same theory should work for you as well.
Old Nov 28, 2005 | 03:25 PM
tx-import's Avatar
sorry fat fingers
Old Nov 28, 2005 | 03:38 PM
MoJoe's Avatar
Nothing a dremel can't fix
Old Nov 28, 2005 | 03:58 PM
CarlJ's Avatar
what's the compressor for? I thought your turned a **** to adjust the internal valving, not pumped them up like air shocks?
Old Nov 28, 2005 | 04:33 PM
MoJoe's Avatar
You can adjust the settings in the cab with the unit instead of going under the truck.
Old Nov 28, 2005 | 04:37 PM
CarlJ's Avatar
So it uses the compressor to turn the ****?
Old Nov 28, 2005 | 05:29 PM
MoJoe's Avatar
Exactly, unless someone else know something different. That is my understanding.
Old Nov 29, 2005 | 02:15 AM
SC_05FX4's Avatar
There's are fittings included with the kit that replaces each ****.
