water temp gauge?
Old Aug 11, 2005 | 11:00 AM
flanaganman's Avatar
water temp gauge?
who knows where the tap is for a mech water temp gauge on the block of a 3v 5.4 ? would like to install one. thanks
Old Aug 11, 2005 | 02:56 PM
DevilSun's Avatar
I believe most people are using the coolant drain plug on the block, and it's on the drivers side face, rear part of the block, below the stock exhaust manifold near the collector flange (relatively)...it's just a hex plug.
Old Aug 11, 2005 | 07:33 PM
are you talking about the one near the dip stick tube?
if so i just tryed that, its not deep enough any ideas?
Old Aug 11, 2005 | 08:17 PM
GB150's Avatar
I ordered an electric water temp gauge the other day. Will the mechanical and electrical gauge sensors mount in the same place? Maybe I'll just put it in the coolant overflow resevoir. j/k
Old Aug 11, 2005 | 08:30 PM
it may but where does it plug in?
Old Aug 12, 2005 | 11:27 AM
DevilSun's Avatar
Hmm, well that sucks. That's where I used it on my 2000 Mustang and thought that's where other people were using it, guess I was wrong (again). That's my only idea...sorry bud.
Old Aug 12, 2005 | 11:56 AM
GB150's Avatar
Heck, I dont know. It hasn't even gotten to my house yet. I may have to enlist the help of one of my wifes coworkers. He's into cars and race cars and he told me he would help me out if I needed it. I'll let you know what I find out.
Old Aug 12, 2005 | 03:24 PM
well the best idea so far has been to cut the heater hose make a tee and put it in there. i did email troyer but hes out of town so maybe next week ill know something.
Old Aug 12, 2005 | 03:26 PM
minus_13's Avatar
Won't a scanguage give you water temp readings... for $120 bucks... no tapping point search... plug and play?
Old Nov 29, 2005 | 12:45 AM
beowulf's Avatar
Yeah, the scanguage tells the water temp as well at air intake temp amongst others....real handy.
Old Nov 29, 2005 | 02:20 AM
i used a mechanical temp gauge used the heater hose check out my gallery for pic of install i made the tee
Old Nov 29, 2005 | 07:10 AM
ChiefDanGeorge's Avatar
YOu can get a digital water temp by putting the message center in the diagnostic mode. To do that the truck should be off. Hold down the trip meter reset push button, then turn the truck on. There are various diagnostic things there, one being the water temp. I assume it must be in Celcius since I was monitoring mine yesterday and it never made it above 90.
There is an oil readout in there as well, however mine just sat on 0.
