Carbon Build Up and Removal
Ok, first I have searched and did not find much. Now, with all this talk about our plugs Iv'e seen things about carbon build up and using a treatment to remove it. What exactly is this process and what is the best way to go about it? Is it something I can do myself? If so does it really work & make a difference or is it just another additive that just takes money out of my pocket?
Thanks JP
I'm going to give it a shot before I change out my plugs. Actually I think I'm going to have the dealer change them out cuz I dont have the guts to do it myself
Hi.
Here's aother
http://www.priproducts.com/recmarine.htm
BTW - it was also mentioned somewhere on here ( MT I think), about a Stealership performing carbon removal via walnut shells as the agent. Might want to check on that ...
Cheers
Grog
Here's aother
:http://www.priproducts.com/recmarine.htm
Cheers
Grog
They’re not hard to do yourself, depending on your mileage and driving habits. I had a lot of rust on mine but it’s because I do a lot of short trip driving and moisture never gets to be burnt off properly. I did mine with a cold engine, but since found out that approximately a 150° to 160° engine temp would be optimal for hard to remove plugs
