Got underdrive pullies on!
Old Nov 15, 2005 | 08:39 PM
asinatra's Avatar
Originally Posted by Intel486
Plus, I'll add on that, according to Mike T, that if you buy a 3-piece mustang pulley set, that you can have problems with the alternator spinning too slow. He recommends the 2-piece sets.
Just because you buy a 3-peice doesnt mean you have to use the alt pulley.
Old Nov 22, 2005 | 04:21 PM
khendrix2374's Avatar
I weighed and measured the stock pulleys.
Stock Crank pully weighs 9.5 pounds and is 7" in diameter.
Water pump pully is 5.25" and weighs less than a pound.
The aftermarket crank pully was lighter... its on my truck now, but I'd guess it was about 4-5 lbs. Plus it was smaller in diameter. The weight was closer to the center. The stock pully has MOST of its weight on the very edge of the pully.
If you have an aftermarket set, measure and weigh the crank pully...
EDIT: I imagine that the sizes of the aftermarket pulleys are the same size as the opposite pully...Ie; the new crank is prolly 5.25" and the new water pump is 7".. I would imagine.
Old Nov 23, 2005 | 03:44 AM
Josiah's Avatar
Khendrix, I received my pulley's today, along with my efans, reviews coming tomorrow and I'll remember to take the weight if you can remind me by replying to this post, before I install them.
Old Nov 23, 2005 | 06:00 AM
reminder
Old Nov 23, 2005 | 01:29 PM
Josiah's Avatar
9lb's for the box that they came in, it looks like 2 pulley's are in there, they are 5" in diameter, at least the one on top is, I'm in a rush so when I get home from the Gym I'll take a better look at them, but for now, those measurements are correct, the pulley on bottom might be a bit bigger.
