How do you get this interior panel off??
Old Nov 8, 2005 | 07:37 PM
AllenB's Avatar
It's the panel right underneath the cigarette lighter. It's a single panel that has a tiny useless shelf. Slants inward from the top. I can't find any screw holes. Any info would be great. I'm thinking of cutting some of this out for a CB radio. This is an 04 Scab XLT
Allen
Old Nov 8, 2005 | 07:55 PM
Squeakers's Avatar
Pull off the surround that goes around the HU, heater, lighter, etc. You may first want to remove the ashtray. It just falls out after that.
Old Nov 8, 2005 | 09:08 PM
AllenB's Avatar
I don't have an ashtray. And what is the HU (I'm sure it's obvious...).
Allen
Old Nov 8, 2005 | 09:12 PM
demoncleaner's Avatar
Allen
Head unit (radio control center)
Jason.
Old Nov 8, 2005 | 09:13 PM
RobNY's Avatar
HU= head unit or radio
Old Nov 8, 2005 | 09:27 PM
asinatra's Avatar
Just hold and pull.
Old Nov 8, 2005 | 09:36 PM
AllenB's Avatar
Here is a pic of my dash. The panel is right under the cigarette lighter.
Allen
Old Nov 9, 2005 | 03:43 PM
-TXF150-'s Avatar
Under the cigarette lighter is the 2 cup holders, is that what you want to remove???
Old Nov 9, 2005 | 03:47 PM
tardman91's Avatar
From the picture it looks like he doesn't have any cup holders. His are on the floor by the 4x4 shifter.
Looks like he's trying to remove that little cubby hole.
Old Nov 9, 2005 | 04:19 PM
Rich04F150's Avatar
I've got the same setup. There is a lighter but no ashtray.
Just pull off the plastic piece surrounding the radio and climate control. I had to grip mine from the top. Just pull straight out, held in by clips. About six of them. Be careful to not rip the airbag light wire off. It unclips.
Once you've done that there are a couple screws holding on the little tray you are talking about. Can't get that piece out without removing the surround. Good luck...
Old Nov 9, 2005 | 04:32 PM
rutherk1's Avatar
Allen
You dont need to take anything out to get that off. Just press on the bottom of the shelf (with your fingers inside the cubbie hole) and pull. It pops right out.
Old Nov 9, 2005 | 04:56 PM
Rich04F150's Avatar
No, don't just pull on that piece.
I just replaced my HU and tried to get that piece off myself. You can't because there are two screws behind the radio surround. This only applies if you do NOT have an ashtray...(most F150's have an ashtray and they're different)
It takes about 5 seconds to pull off the surround. Don't worry, just pull straight out, it won't break. Then two screws hold on the little cubby.
FYI- I have a regular cab with the airbag on/off switch in that cubby. Mine may be different but I believe all trucks with no ashtray and floor shift transfer have the same lower dash setup.
Old Nov 9, 2005 | 05:30 PM
AllenB's Avatar
I don't have an on/off switch for the airbag, but other than that yeah...just the small "cubby hole"
Thanks guys!!
Allen
Old Nov 9, 2005 | 08:40 PM
Steamin's Avatar
Not a switch, a light. I
The wire is short, and looks easily broken.
