How hard are fender emblems to take off...
Old Nov 2, 2005 | 10:31 AM
Dolemite's Avatar
I got my Harley emblems in today and I want to take the old ones off...How should I go about that?
Old Nov 2, 2005 | 11:48 AM
FX4&EXCURSION's Avatar
Not toooo hard. Just need to take your time. The emblems are adhered with double sided tape in addition to the emblem having alignment posts that go into the fender. I would take some fishing line or something comparable and place the line behind the emblem and start working the line back and forth while slightly tugging back. Eventually it will unstick itself. If the emblem is on pretty good you can take a hair dryer and blow hot air behind the emblem edges to heat up the sticky tape then start tugging back again with the fishing line. Be careful around your paint. Don't want to see you scratch it. Good luck and take some pics when your done. Like to see it.
Old Nov 2, 2005 | 12:46 PM
asinatra's Avatar
On the subject, harley emblems are roughly $30/ea list and if you dealer likes you you can get them for about $15/ea
Old Nov 2, 2005 | 05:28 PM
YellowFX4SCrew's Avatar
I would recommend that you tape off the old emblem prior to removing it so you have a guide to insure the new one is level somehow.
I took dental floss and doubled it up and then used it in a "sawing" action from the top corner. Once I was about 1/4 of the way through, I was able to pull it off carefully the rest of the way. Take some adhesive remover and clean the rest of the glue off and the rest is history.
Good luck.
Old Nov 2, 2005 | 06:12 PM
Dolemite's Avatar
I got my grill for right over 100 then I got the emblems for 21 bucks...people are paying 80 and 90 bucks for them on ebay!!
Old Nov 2, 2005 | 06:22 PM
Are the grill and emblems on yet?
Old Nov 2, 2005 | 06:39 PM
Dolemite's Avatar
OK I got them off.....It was pretty easy...What can I use to get the sticky residue off of the paint. I know alcohol does the trick on glas, but is it safe for paint?
Old Nov 2, 2005 | 06:40 PM
Dolemite's Avatar
i've got the grill on.....As soon as i get the emblems on...I'm going to wash take pics and post!!
Old Nov 2, 2005 | 06:42 PM
Sweet!!!! Hurry up!!!!!!!!!!!!!!!!
Old Nov 2, 2005 | 06:44 PM
Dolemite's Avatar
Sorry I should have read this all the way thru....I'm going to go to auto zone to get adhesive remover.....I couldn't use the old one as a guide...they're different sizes
Old Nov 2, 2005 | 06:46 PM
Goo gone is good stuff to you use. Shouldn't matter as far as a guide, the new emblem alignment posts should line the new emblem right up.
Old Nov 2, 2005 | 07:00 PM
thetruck's Avatar
A grinder will get it the left over adheisive off quickly.
Old Nov 2, 2005 | 07:38 PM
Dolemite's Avatar
I bought sticker shock sticker remover it seemed to be the safest for paint. I'm going do it up!!!
Old Nov 2, 2005 | 08:24 PM
Dolemite's Avatar
The chit don't work worth a damn..Is alcohol ok?
