Oil Gauge
Oil Gauge
This Is my first ford truck and I love this truck.
I have a crazy question, Maybe someone can answer or tell me to do somthing better withmy time.
The oil gauge on my truck does not move at all. It goes to a little above the half way mark when started and stays there no matter how hard I hit the gas or stop or anything. This gauge just does not move.
I thought this was an oil pressure gauge, which should rise a little when you take off from a stop.
I have own several cars and trucks and the ones with an oil gauge move at different points depending on engine speed.
Just wondering If anyone else has noticed.
Originally Posted by Quintin
The really fun part is that by the time the light comes on and the gauge bottoms out, the damage may already be done.
Originally Posted by DevilSun
This is SO TRUE! Quick story here. Last year I believe it was, went to SEMA. Drove my Roush Mustang down there. On the way back, just north of Sacramento, cruising along at 75 at around 9:30 PM or so...and something catches my vision out the corner of my eye. My newly installed mechanical oil pressure gauge just swept all the way down to zero, I tapped it once and started pulling over immediately and shutting off the car. By that time, car was smoking from the oil dumping. My spin-on remote oil filter piece came lose, blew the ring out from the piece, and dumped 6 QTS of oil in a matter of a few seconds ALL OVER MY CAR and directly into the driver side front wheel. Point of the story, my mod caused the problem, however, another one of my mods saved my car. By the time I was pulled over and shutting the car off, I still had ZERO OIL PRESSURE according to my mechanical gauge, and the stock gauge cluster read just fine. I have ZERO faith in the stock oil pressure gauge after my first hand experience...needless to say, absolutely nothing happened to the engine due to the real gauge and quick reactions. I pissed off some people though because I oiled the s#$t out of their car and the highway, not to mention my own.
Originally Posted by SAJEFFC
The oil pressure gauge on all Ford's now is really just an idiot light with a needle. It's designed to jump to the same place on the guage every time when it reads a pressure of about 8-10 pounds or above...pretty useless really.
The car was so warm from the weather by the time I got it home, there wasn't much oil left on the side...and nothing a pressure washer couldn't clean off, including most of the undercarraige...would you believe a day or two later it didn't even look like anything happened, minus all the dripping oil I had to hand clean up in my garage
