4wd Lift Blocks Removed
I have a question for those who have removed their lift blocks on a 4wd. Have you had any problems? I am curious about the length of the shocks. Are the shocks "bottoming out"? Any information would be great. I have a set of 2wd u-bolts coming and would like to know what I'm getting into.
for those of youwith a 4x4 and that have taken off your lift blocks and u bolts i would like to buy a set. please let me know how much you want for them i really want a set. please e-mail me at CO_Malone898@hotmail.com. thanks
well I did the opposite. I have a two wheel drive and put blocks in from a 4x4. I had to change U-bolts and nuts, the bolts are different length and diameter. During reassembly we noticed the stock 2wd shock was too short to span the distance at full droop, so I put a set of shocks on that we had laying around, they came off a new FX4. Side by side they appeared to be 2-3 inches longer than my 2wd shocks. Personally I would take this opportunity to upgrade shocks while your in there and have everything already apart. I would have done that if I had thought that far ahead.
yea thats what i want to do. i think im gonna go 3.5 lift spindles along with my 2.5 spacer and add a leaf in the back with the blocks. so thats why i really want some lift blocks. but thanks for the info.
Upgrading shocks is not a bad idea. Can anyone recommend a shock for this application? 4wd with 2wd rear ride height, non-adjustable, good ride quality & reasonably priced.
Originally Posted by Michael Joseph
indyeng, i recently changed rear shocks (same as you 4x4 lowered) and went with bilsteins for a 4x2. nice ride easy install from e shocks
Thanks for the reply. To those checking this site it should be eshocks.com.
You bought 2wd shocks, correct? Thanks again.
