AF1 install problems
Old Sep 9, 2005 | 09:44 AM
  #31
wstahlm80's Avatar
Originally Posted by jpdadeo
If negative posts were to sway opinion, nobody would drive a 04. There are thousands of negative posts about vibration problems and everything else imaginable (ashtray noise, leaks, squeaks, A/C, tires, seats, tailgate, etc, etc, etc, etc, etc)
I know....I know....I read those posts as well....other than the rear-end shudder...my '04 has been superb....but like I said...these boards tend to amplify the negative....
It just seems to me that there are a lot of design flaws/inconsistancies being reported with the AF1....which makes me want to hold on to my $300 until things are "figured out".....
Old Sep 9, 2005 | 09:46 AM
  #32
carpenter's Avatar
AF1 install problems (name of the thread)
So tell us exactly what problems you encountered during your installation of the AF1
I’m curious as to what your first hand experience was
I Never had any problems with an installation of an AF1. I was lucky enough to have read the threads concerning the problems and issues related with the AF1 and choose to purchase a K&N FIPK kit instead.
I guess I didn't understand there was a requirement to have purchased and installed an AF1 kit in order to relate any Air Intake Systems information good or bad concerning any manufacturer.
Perhaps you can show me where that requirement is, or is it a personnel requirment of yours?
What is your major problem or issue here, or is it that you just want to pick a bone with someone or what.. Get a life my friend....
Old Sep 9, 2005 | 09:55 AM
  #33
dzervit's Avatar
I had the Xcal and Magnaflow muffler for several months before the AF1. That was my last mod on the *bang for the buck* list but I noticed a huge power gain difference immediately on the first test-drive.
go figure
Huh... I've noticed a little, but maybe the noise is distracting me from the performance? I still have yet to make my ¼ runs with the g-timer post-AF1. The numbers should tell the tale.
Old Sep 9, 2005 | 10:07 AM
  #34
jpdadeo's Avatar
The biggest telltale sign was the burnout. Before, with the Xcal & Magnaflow I could get maybe 5 or 6’ tops from a tromp, no power braking, but now it more like 10 to 12’ (I got a 3:55 LS)
Before the Xcal it just went huh
Old Sep 9, 2005 | 10:16 AM
  #35
jpdadeo's Avatar
Originally Posted by carpenter
(Snip
Requirements
1. Dermel or small file
2. Good hammer to straighten out bent tube
3. Extra parts to replace those missing
4. Leather AF1 gloves (without these installation will fail)
5. Extra life
Old Sep 9, 2005 | 10:23 AM
  #36
Marc Carpenter's Avatar
I hope nobody takes this personal, but either a lot of people here have NO mechanical abilities, or just want to b!tch about something..Too many "me too's" also.
Look, its apparant that some of the Air Force 1 intakes are not perfectly manufactured, which is upsetting to me also, but for chr!st sake people, suck it up and install the thing. My 12 year old daughter has actually helped me install several of the 3 Air Force 1 intakes I have purchased in the past 2 or 3 years..Your driving a $30,000.00 + truck that also has inperfections and issues so why cry over a $300.00 intake ???
Old Sep 9, 2005 | 11:19 AM
  #37
carpenter's Avatar
Requirements
5. Extra life
Ok, now I understand. I'll check my tool box to make sure I have those leather gloves you speak of.
Old Sep 9, 2005 | 12:34 PM
  #38
phenom's Avatar
Send her over, because my screw holes aren't even in the same park, unless you count Yellowstone.
Old Sep 9, 2005 | 12:35 PM
  #39
phenom's Avatar
lighten up, francis.
You never even had an AF1? Why are you even in this thread? Read the title of the thread - it's not about any air intake systems; it's about the Air Force One. Tell me again who needs a life.
Old Sep 10, 2005 | 11:30 PM
  #40
DRHRSH's Avatar
I just received my AF1 from Troyer. I only waited two weeks to get it. Troyer kept me well informed of shipping date, and didn't charge my credit card till it shipped. I did have to spend about 90 seconds refining the bung for the MAF sensor. All other parts fit well. Total install took 30 minutes, max. Yes, the directions miss a few key points, but those with mechanical skills will have no problems. Noise is a personal preference, but I agree with others, I only hear it when I romp on the accelerator. I do not hear it when cruising.
I did ,however, have my CEL set immediately. I reset it per the instructions, and after 20 minutes of driving I have the CEL on again. Now what?
Old Sep 12, 2005 | 06:30 AM
  #41
carpenter's Avatar
I'll make the choice to post when I feel that I have a comment that will be of some help to the remaining members of this board.
Who the heck do you think you are trying to tell me when I should or shouldn't post. Bite Me!!!
Old Sep 19, 2005 | 10:59 PM
  #42
phenom's Avatar
Really, if you're gonna go into a thread about an item that you don't even have, or have never owned, and start trying to push people around, then you deserve all you get, or think you get.
Now, read my next post about the crappy Air Force One.
Old Sep 19, 2005 | 11:03 PM
  #43
phenom's Avatar
So basically, as it turns out, I'm pretty much an idiot.
I misread the airflow direction of the tube, and when the MAF sensor was flipped around properly, it fit perfect. Absolutely perfect. The dremel stayed in its case, and the screw holes lined up perfectly. It's crazy - almost as if they designed it that way.
The post/grommet issue was hardly an issue, as it turned out. It was just a matter of installing them loose, and tightening the screws after.
The vibration damper was also a piece of cake, although the instructions could've been better about this piece, as well as the rubber "washer" that went on the mounting bracket.
I got this help from someone at AF1 directly, and I really wish I could remember his name. After contacting Troyer, they got AF1 in touch with me within just a couple hours. I missed the call, called him back, missed him, and he got back to me within minutes.
The AF1 is absolutely dead silent until I step on it, so my worries about noise issues were unfounded. All in all, I'm completely satisfied with my purchase, and how well it works.
Old Sep 21, 2005 | 02:25 AM
  #44
Hap Hazard's Avatar
Timely thread in my case. I purchased an AF1 some months ago so it must have been an old style, but for many time-related reasons didn't install it until a few days ago. Not being particularly mechanically inclined (last time I worked on my own vehicle was 30 yrs ago -- motorcycles), and having read many posts here about install and operational problems, I had concerns, but forged ahead anyway and the install went surprisingly easy for me. I finished in 2 hours or so. My biggest snag was getting the metal bolt threaded through the mounting bracket and into the tube, which took some time. I wasn't ever sure how to set up the washers either, so I guessed. But I found the instructions mostly straightforward, with good photos, and even down to the warning to be sure to disconnect the negative battery terminal.
It is a bit noisy when I step on it, but not at all noticeable in normal cruise. I might expand the pipe end as discussed in an earlier thread in the hope that the bottle noise will abate on hard throttle.
No CEL so far. I did notice a marked valve knock on heavy throttle but only the first few minutes, and never since.
Old Sep 21, 2005 | 01:14 PM
  #45
purpony's Avatar
Thats why I ordered an AirAid instead from summit racing. 2 days and its at my door. No waiting around and then having to mod it to fit or sound right... plus i dont like the idea of a metal tube soaking up the heat under the hood.
