Taking the Dash apart
Old Sep 6, 2005 | 09:41 PM
HIDPLANET's Avatar
I had squeaks initially but I fixed it.
My squeaks came from the fact that the head was slightly rubbing against the inside of the bezel. You need to square it up and align it so it totally clears. It it a tight fit since the new kit fits so close, but it can be fixed. Just tweak it and test fit until there are no more squeaks.
Old Sep 6, 2005 | 09:43 PM
ThumperMX113's Avatar
It sounds like a damn mouse is inside of my dash. Im just going to take it back to the shop I had do the install and have them re-adjust it.
Old Sep 6, 2005 | 10:42 PM
dlewis1340's Avatar
Make sure the little thin plastic disks are still on all of the anchor tabs. these are designed to fight squeeks.
Old Sep 21, 2005 | 09:26 PM
geokar01's Avatar
When you take it off can you access that coin pocket to the left? I am thinking about adding another 12v outlet like I heard the LT has, this is where I am adding my IPOD and bracket....just did not know if I could access it from there...I wonder if there is a wireing harness for that already?
Old Sep 21, 2005 | 10:10 PM
mslc1's Avatar
there is a nylon tool specifically for ford dashes...google search ford dash tool...about 8 bucks..definately takes the scary part out of removing dash...btw...what is up with the cowl vent just flopping against the windshield...talk about noisy....added some rubberized shelf material for RVs to add cushion between vent and windshield
Old Sep 22, 2005 | 05:15 AM
inbred's Avatar
You only need to get the radio bezel off which has been covered. In case someone searching in the future digs up this thread for another reason, here's a picture for them:
Old Sep 22, 2005 | 07:39 AM
geokar01's Avatar
awesome thanks
Old Sep 22, 2005 | 11:44 AM
Inhot's Avatar
Picture software
Hey TX150,
A little off topic, but what program do you use to add the arrows and text to your pictures?
Old Oct 29, 2005 | 10:44 AM
GPOjunk's Avatar
Great pics and instructions TXF150. I was just getting ready to install the PIE unit and you saved me a lot of aggravation.
Old Oct 30, 2005 | 07:29 PM
countyboy04's Avatar
I wonder why the #6 bolt calls out a torque spec?
Old Oct 30, 2005 | 08:19 PM
OnBelay's Avatar
Originally Posted by Thrill Racing
Am I the only tool to break one of those darn fuzzy clips when taking that piece off?
Does anyone know were I can get another one or two at.
Will
I don't know where you can get them, but I know the dealer cannot get them for you-they come with the panel (which runs +/- $85)
Old Nov 3, 2005 | 01:47 PM
skeeter USA's Avatar
Theres some metal tipe of frame on the back side of the dash ,I think it tightens to that I took number 6 off too do my traler brake hook up i
Old Nov 3, 2005 | 03:56 PM
MIGHTY 150's Avatar
that avator is awesome...shouldn't you be from kentucky or tennesee though???
