Lower ass end?
Old Aug 19, 2005 | 09:11 PM
kd4crs's Avatar
FX4&EXCURSION,
Yes it is 4 wheel drive. I don't do any off-roading so lowering it isn't a problem.
Old Aug 19, 2005 | 09:13 PM
SteveVFX4's Avatar
Originally Posted by FX4&EXCURSION
Thanks! I was asking if your truck is 4 wheel drive?
you should know, you have an FX4, and all FX4's are 4x4!
Old Aug 19, 2005 | 09:24 PM
FX4&EXCURSION's Avatar
woops
Got me there.
Old Aug 19, 2005 | 11:01 PM
mitchman's Avatar
All FX4's are 4x4's. (my guess is that's what the "4" stands for)
Thanks for the photo. Looks good!
Old Aug 20, 2005 | 01:54 AM
2000F150HD's Avatar
I had lowering Shackles on my 2000 HD truck... And they are easy to install. THey would work on the 4x4... but changing out the block is a better option, because the shackles lower the back of the leaf spring and therefor cause the driveshaft angle to change... sometimes requiring shims.... So, if i was going to lower a 4x4... i would switch the block's out first and put in a shackle if i wanted it lower.
-stephen
