Is this normal
Old Aug 12, 2005 | 10:51 PM
radz's Avatar
Is this normal
Old Aug 12, 2005 | 11:19 PM
casualtr's Avatar
I thought the F-150 usually idles at 700-800 rpms. Not really sure what you're asking but it looks normal to me.
Old Aug 13, 2005 | 12:31 AM
ThumperMX113's Avatar
Ditto.
Old Aug 13, 2005 | 02:10 AM
porkchop's Avatar
Originally Posted by radz
...I know it's on zero when the engine is off. .
I should hope so.
Old Aug 14, 2005 | 09:54 AM
jimmy k's Avatar
are you talking about the tach or the speedo?
Old Aug 14, 2005 | 10:03 AM
04fx4Scab's Avatar
that's normal, don't worry about it. mine did the smae thing after the update. i think they bumped up the idle rpm in park for what ever reason. as soon as i shift out of park it drops to around 500-550.
Old Aug 14, 2005 | 02:08 PM
Matt 05'FX4's Avatar
Was the RPM suppose to be in Zero?
That's not too hard to understand.....I read that as to say that when you are idling, in park, parking brake on, the tach reads "0". Sounds like you have a problem......
Old Aug 14, 2005 | 02:44 PM
PiggNFord's Avatar
If I understand this, the engine is running, but the tach shows ZERO? That's not right. Try to sweep the gauges, if that don't fix it, take it back and let the dealership handle it.
Old Aug 14, 2005 | 03:21 PM
RockyJSquirrel's Avatar
I suspect our friend 'radz' has absolutely no clue what a tachometer is or what it indicates. 'rpm' is the abbreviation for 'revolutions per minute'. A revolution is one complete turn of the crankshaft in your engine. If your tachometer indicates 0 rpm, then that means your engine is stopped. If the engine is running, it is not stopped.
Old Aug 14, 2005 | 05:23 PM
04fx4Scab's Avatar
his picture clearly shows the truck in park, parking brake on, heading of NE with a temp of 81F, spedo at zero and the truck idling a hair under 750. that's normal. if radz is confused between the spedo and tach he needs to be riddin' a bike.
Old Aug 14, 2005 | 06:37 PM
radz's Avatar
Talking
Ok i was just confuse and pardon my ignorance. i got a 5 spd 90 mustang when it idles, the tach is close to zero. Truck idles more than 700 rpm. Maybe its the mustang. Just confused thats all . Thanks for clearing this out. Funny i was just thinking of getting a bike, coz of todays gas prices . dammit 59 bux to fill up. That's for regular
Old Aug 14, 2005 | 06:52 PM
04 RED LARIAT's Avatar
dammit 59 bux for regular
If its 59 dollars for regluar you better get a bike. ...guess you are talking about a complete fill up.
