Anyone pulling heavy 5th wheel campers?
How much can my FX4 (with trailer pkg) tow?
Is this too much.... Glendale Titanium, Dry weight 7996 lbs. Pin weight 1679 lbs?
I pull a travel trailer now ~ 6500lbs with a 800lb tongue weight and weight distribution hitch, but I want to upgrade to a fifth wheel.
Any advice?
Any advice?
Originally Posted by Quintin
I'd recommend a bigger truck.
Originally Posted by suncoast ford
What is your wheelbase and gear ratio?
What size wheels?
What is maximum loaded trailer weight?
What size wheels?
3.73's
18's
loaded trailer weight ~10100 lbs
You're right Quintin, that's not what I wanted to hear
...... but I thought that would be the answer.A guy camping beside me had a 04 Dodge Hemi and pulled a 27' Terry ...GVWR 9500lbs, Dry pin weight 1098lbs.... and said it pulled like nothing was behind him.
We never said those Dodge guys were bright. I suppose you could do it, but you'd be at the limits of practicality and safety. A Superduty could get the job done that much easier, that much safer, with a whole lot less wear and tear on the truck.
I guess the FX4 stays in the driveway and the new fifth wheel stays at the dealer. And some greenbacks stay in my pocket.
It was all my wifes idea anyways..
Sorry... Scab 6.5' box (what ever the wheelbase is.. i forget now)
3.73's
18's
3.73's
18's
I wouldn't recommend anything shorter than an eight foot
bed for fifth wheel setups. I would also advise buying a diesel for towing
that heavy trailer.
I have pulled a fifth wheel camper, 30" and 10K#s, I have the 5.5' bed. it tows dam good for a half ton, milage didnt even suck that bad. It was only for several hundred miles at a time.
But a bigger truck would have been nice..
5.4L, 3.73 screw fx4
Supposed to be a quote thingy!
I call bu!!crap my dad has a 26' fifth wheel GVWR 7200lbs and a 16' fiberglass boat that weighs 2200lbs total weight was 9950lbs for fifth wheel and boat. Driving 100km/hr he got 10.6mpg and he said he sure knew it was there. In his 3/4 ton quadcab HEMI 4+4 with 3.73 gears.
I have a 2004 dutchman sport with a power out living room, and I pull it with my 04 fx4 s/c 6.5' box 3.55 gears trailer tow package, this trailer fits the truck just right empty 4900lbs, gv 10500, I have pulled it full or fresh water, gray water and black water, if your wife is in to the 5vers this is it (my opinion) Last trip was about 1200 mile averaged 11-13 miles per gall, runs down the freeway at 2200 rpms at about 60, in no way does it put extreme loads on the truck. pin weight is 1500 I think. Find a dutchman dealer and check it out. And a freind of mine had a Hemi towed is 5000# tt to yellowstone from Mn .. Had a Hemi
